RCA Connector 90° Angled 24k Gold-Plated Ø8mm (Unit)
This gold-plated RCA connector with 90° angle is ideal for DIY projects. The 90° angle is particularly practical for installations in confined spaces. This robust connector's aluminum body prevents interference.
Reference : 18090
13,90 €tax incl.
11,58 € tax excl.
Shipping date: 28-05-2026.
Connecteur RCA
Connecteur RCA Coudé 90° Plaqué Or Ø8.2mm (Unité)
This gold-plated RCA connector with 90° angle is ideal for DIY projects. The 90° angle is particularly practical for installations in confined spaces. This robust connector's aluminum body prevents interference. The gold plating on the contacts makes it resistant to oxidation and corrosion.
This RCA connector accepts cables up to Ø8mm in diameter. Assembly is quick and easy, since no soldering is required. The cable is also held securely to the connector.
Product typeRCA connector
Max. cable diameterØ8
Conductor materialCopper alloy
Conductor platingGold 24k
Body materialAluminum
Angled connector90°
Mounting typeTo screw
Dimensions37 x 30 x 12mm
ColorSilver / Gold
Weight0.3kg
Package1x Gold-plated 90° angled RCA connector (sold by unit)
Max cable diameter (mm)8.0
ConnecticMale
This gold-plated RCA connector with 90° angle is ideal for DIY projects. The 90° angle is particularly practical...
