VIABLUE T6S Gold Plated RCA Connectors Ø9.5mm (Pair)
Viablue T6s Connecteurs RCA plaqué Or (set x4) Ø 9.5mm
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while providing excellent oxidation resistance for greater durability.
Reference : 3142
19,92 €tax excl.
Shipping date: 06-10-2022.
Orders placed before 11AM (GMT+1) will generally be shipped the same day (working day).
Shipping from France
Billing in France
Technical support in France
Viablue T6S
Viablue T6S Connecteurs RCA Plaqués Or Ø9.5mm (La paire)
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while providing excellent oxidation resistance for greater durability. The connector body is made of matt black aluminium with the most beautiful effect. M4 1.5mm hexagon socket screws allow the cable and connector to be held very securely in the body. The T6S RCA accepts cables from 4mm to 9.5mm in diameter and comes with two reducers to perfectly match the diameter of your cable.
Product typeRCA Connectors
Contact platingGold 24k
Shell materialAluminium
Min/Max Cable diameterMin : 4mm
Max : 9.5mm
Total length45mm
Shell length30.5mm
Shell diameter13.5mm
ColorMatt black
QuantitySold per pair (1 connector with red ring, 1 connector with black ring)
PlatingGold
Max cable diameter (mm)9.5
Mounting typeTo weld
ConnecticMale
4 reviews
Bon rendu sonore
C'est l'essentiel, je les préfère du coup aux neutrick nf2cb2 qui sont plus douce mais plus ternes, en association avec le stratos.
C'est naturel aéré, et pas fatigant.Les fiches sont plutôt réussies esthétiquement.
This review has been posted for VIABLUE T6S Gold Plated RCA Connectors Ø9.5mm (Pair)
Viablue rca
J'ai acheté ses fiches pour allée avec le cable sub de chez viablue également, belle finition, excellente qualité,les basses sont beaucoup plus tendus et fermes, je recommande vivement.
Elle sonne bien
Je suis satisfait de c est connecteurs RCA facile à monter (avec câble modulation neothec occ) Elle procure un son équilibré,filé dans le haut du spectre , timbrée, avec une bonne assise dans les basse , une bonne transparence,seul bémol , qui n est pas au niveau du son ,les visse de serrage peuvent tourner dans le vide après plusieurs montages.
très bon produit pour un prix correct ! A recommander
These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good...
