XANGSANE XS-T1061 RCA Connectors 24k Gold Plated Ø9mm (Set x4)
These XS-T1061 RCA connectors from Xangsane feature a quality design using top-of-the-range materials. The contacts are made of 24k gold-plated copper alloy. This gives them high conductivity and resistance to corrosion and oxidation.
4.8 / 5
Reference : 18099
9,85 €tax incl.
8,21 € tax excl.
Shipping date: 22-09-2026.
XANGSANE XS-T1061
XANGSANE XS-T1061 Connecteurs RCA Plaqué Or 24k Ø9mm (Set x4)
These XS-T1061 RCA connectors from Xangsane feature a quality design using top-of-the-range materials. The contacts are made of 24k gold-plated copper alloy. This gives them high conductivity and resistance to corrosion and oxidation. The body of these connectors is also made of copper, making them tough and durable. The structure of these RCA connectors allows them to be completely disassembled for easy screw mounting. Moreover, their design makes them self-locking, so all you need to do to tighten these RCA connectors is turn their body counter-clockwise. They accept cables up to Ø9mm in diameter and are sold per 4.
Product typeRCA Connectors
Contacts materialCopper alloy
Contacts plating24k gold
Body materialCopper
Max. cable diameterØ9mm
Mounting typeTo screw
Self-locking
Total dimensions55*Ø14mm
Weight26g
PackageSet x4
Max cable diameter (mm)9.0
ConnecticMale
14 reviews
Tosi hyviä
Hintalaatu suhde aivan mahtava! Tähän hintaan ei parempia liittimiä saa varmaan mistään. Ja plussaa tietenkin se että ei tarvitse kolvata!
This review has been posted for XANGSANE XS-T1061 RCA Connectors 24k Gold Plated Ø9mm (Set x4)
Parfaites
Ces fiches sont de très bien conçues !
Connecteur RCA
Très bonne qualité de fabrication, donne une impression de robustesse au touché. Par contre il faut utiliser un câble avec le diamètre extérieur adapté pour que la tresse de masse soit en contact fiable avec la vis de blocage, ou dénuder sur une bonne longueur pour pouvoir enrouler soigneusement la tresse de masse autour de la gaine du câble de façon à augmenter le diamètre extérieur. J'ai utilisé un peu de soudure pour fixer la tresse enroulée. Pour mon deuxième câble,j'ai soudé la masse directement sur le connecteur côté intérieur. Si vous soudez côté extérieur impossible de refermer le connecteur, ou il faut une soudure d'1mm d’épaisseur. Ouais pas simple. Malgré tout, j’aime bien la solidité et l’aspect de ces connecteurs . Rodrigue
Bonne qualité, peut-être un peu lourdes pour un appareil léger comme un DAC qui versera vers l'arrière.
Elles sont un peu larges, vérifiez l’écartement des borniers sur l'appareil auquel vous destinez ces Fiches.
Comme Cédric J, j'ai fini par souder la tresse du câble au corps, pas eu besoin de modif pour cela.
chauchau
RQP imbattable. Facile à monter. Merci Audiophonics.
These XS-T1061 RCA connectors from Xangsane feature a quality design using top-of-the-range materials. The...
