VR109 RCA connectors Viborg with pure copper conductor. Ideal material to enjoy a superior conductivity and preserve your audio signal in all its clarity.
The outer shell is constructed from an aluminum and alloys in order to take advantage of a light structure, strong and durable. The VR109 can be connected to mass wirings without placing an excessive pressure to the female connector.
Connector's isolation is made of PTFE which is an efficient protection against thermal stresses, corrosion, humidity. This allows the connector to keep its electrical properties for a long time.
| Specifications | |
| Type | RCA connector |
| Kind | Male |
| Driver | Pure copper |
| Shell | Aluminum alloy |
| Insulation | PTFE (white) |
| max cable diameter | 9.5mm |
| Dimensions | 13.9φ x 14.4mm x 51.5 mm |
| Connection | Solder |
| Package Contents | |
| Red ring connector | x2 |
| Black ring connector | x2 |
| Max cable diameter (mm) | 9.5 |
| Mounting type | To weld |
| Connectic | Male |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | None |
