AUDIO-TECHNICA AT-VM95E/H Elliptical Stereo Phono Cartridge with AT-HS6 Headshell
The Audio-Technica AT-VM95E/H is more than just an entry-level phono cartridge; it embodies Audio-Technica's philosophy of making high-fidelity audio accessible to all. A worthy successor to the hugely popular AT95E, this elliptical dual moving magnet stereo cartridge from the VM95 series has been meticulously engineered to deliver a rich, detailed listening experience capable of transforming the way you rediscover your vinyl collection. As a result, the AT-VM95E promises impressive audio performance and unrivalled ease of use.
Reference : 20875
89,00 €tax incl.
74,17 € tax excl.
Audio-Technica AT-VM95E/H Elliptical Stereo Phono Cartridge with AT-HS6 Headshell
Audio-Technica AT-VM95E/H cartridge
The Audio-Technica AT-VM95E is more than just an entry-level phono cartridge; it embodies Audio-Technica's philosophy of making high-fidelity audio accessible to all. A worthy successor to the hugely popular AT95E, this elliptical dual moving magnet stereo cartridge from the VM95 series has been meticulously engineered to deliver a rich, detailed listening experience capable of transforming the way you rediscover your vinyl collection. As a result, the AT-VM95E promises impressive audio performance and unrivalled ease of use.
In this version, the AT-VM95E cartridge is mounted on the AT-HS6BK headshell, for a total weight of 15.5g. Assembly and testing are carried out at Audio-Technica's Fukui factory in Japan.
Key features:
  • Aluminum cantilever
  • 4mV Output voltage
  • Body compatible with all VM95 styluses
  • Replaces AT95E and AT95EX
  • Frequency response: 20Hz-22kHz
Audio-Technica AT-VM95E/H: Robust design and optimum audio performance
At the heart of the AT-VM95E is a redesigned cartridge body, characterized by its rigidity and low resonance. This design minimizes unwanted vibrations, guaranteeing more faithful playback and remarkably clear sound reproduction. The 0.3 x 0.7mil elliptical stylus, combined with a sturdy, lightweight aluminum cantilever, ensures precise tracking of the groove on your records. This combination ensures exceptional reproduction of the finest musical details, from deep, punchy bass to crystal-clear highs, all with an extended frequency response from 20Hz to 22kHz. The cartridge delivers an output voltage of 4.0mV, providing a powerful, clear signal for optimum compatibility with most phono preamplifiers.
Audio-Technica AT-VM95E/H: Simple installation and uncompromising scalability
One of the major advantages of the AT-VM95E is its ease of installation. Thanks to threaded inserts integrated directly into the cartridge body, mounting on your cartridge holder or tone arm is child's play. All you have to do is screw the cartridge directly on, making installation quick and safe.
But the AT-VM95E's versatility doesn't stop there. It's part of the VM95 series, which means its body is compatible with a full range of Audio-Technica replacement stylus, from conical to Shibata, elliptical to Microlinear. This unique feature offers you a flexible upgrade path, allowing you to upgrade your cartridge and refine your listening experience as and when you wish, without having to replace the entire cartridge.
Audio-Technica AT-VM95E/H: An all-purpose cell built to last
Whether your passion for vinyl is new or long-standing, the AT-VM95E is designed to meet a wide range of needs. It's ideal for everyday listening, offering sound quality superior to that of many pre-mounted cartridges. Its precision makes it an excellent choice not only for audiophiles concerned with sound reproduction, but also for DJs looking for a reliable, high-performance cartridge. What's more, its ability to play mono vinyl (LP) further extends its versatility. To maintain optimum performance and preserve your precious records, a vertical contact force of 1.8 to 2.2 grams (2.0 grams being the recommended standard) is recommended. And to guarantee consistent sound quality, don't forget to replace the stylus after around 300 hours of use, a simple and economical process thanks to the AT-VMN95E replacement stylus available.
Product typePhono cartridge with headshell
Frequency response20Hz - 22kHz
Channel separation20dB (1kHz)
Vertical track angle23°
Vertical tracking force1.8g to 2.2g (standard: 2g)
Stylus mountingBonded round shank
Recommended load impedance47000Ω
Coil impedance3.3kΩ (1kHz)
DC resistance485Ω
Coil inductance550mH (1kHz)
Output voltage4.0mV (@ 1kHz, 5cm/sec)
Output channel balance2.0dB (1kHz)
Stylus typeElliptical
CantileverAluminum pipe
Static compliance17 x 10-6cm / dyne
Dynamic compliance7 x 10-6cm / dyne (100Hz)
Mounting1/2" centres
Cartridge weight15.5g
Recommended load capacity100-200pF
Stylus size0.3 x 0.7mil
Cartridge typeVM Stereo dual magnet
Cable used for coilT.P. Copper
Dimensions (H x W x D)21.2 x 21.4 x 62.4mm
The Audio-Technica AT-VM95E/H is more than just an entry-level phono cartridge; it embodies Audio-Technica's philosophy of making...
