The Audio-Technica AT-VM95SH is one of the flagship cartridges in the VM95 series, offering exceptionally faithful sound reproduction thanks to its Shibata stylus. Designed for demanding audiophiles looking for the ultimate in precision and harmonic richness, this cartridge brilliantly replaces the AT440MLb and AT150MLX models, bringing a new dimension to your vinyl listening. If you're looking for a cell capable of revealing every nuance of your recordings, the VM95SH is your ideal ally.
Key features:
At the heart of the AT-VM95SH's performance lies its naked Shibata stylus, a cutting profile renowned for its ability to follow the groove with extreme precision. This type of stylus offers increased contact with the groove wall, enabling maximum recovery of audio information, including the highest frequencies and subtlest details. Mounted on a sturdy aluminum cantilever, the Shibata stylus guarantees minimal distortion and an extended frequency response from 20Hz to 25kHz. With an output voltage of 3.5mV, the cartridge delivers a balanced signal, ready to be amplified with remarkable clarity. Channel separation of 23dB and a channel balance of 1.5dB testify to its ability to create a vast, incredibly defined soundstage.
Like all VM95 series cartridge, the AT-VM95SH incorporates threaded inserts in its body, greatly simplifying the installation process. There's no longer any need for tedious nuts; a simple screw connection is all that's needed to secure it to your headshell or tone arm. In addition to its ease of installation, the VM95SH offers remarkable scalability. Its body is fully compatible with all VM95 series replacement stylus. This means you can not only replace the worn-out Shibata stylus (reference AT-VMN95SH) to maintain its optimum performance, but also experiment with other stylus profiles (conical, elliptical, MicroLinear) if your listening preferences evolve. It's a lasting investment in audio quality.
Designed for the most demanding listeners, the AT-VM95SH is ideal for revealing the full potential of your recordings, whether modern pressings or classics from your collection. To ensure optimum performance and longevity of your vinyl records, a recommended vertical pressing force of 1.8 to 2.2g (2.0g standard) is recommended. The estimated service life of a Shibata stylus is around 800 hours of use, making it a durable choice for extended listening sessions. The option of replacing only the stylus, and not the entire cartridge, underlines Audio-Technica's commitment to durability and economy.
Product type | Phono cartridge |
Frequency response | 20Hz - 25kHz |
Channel separation | 23dB (1kHz) |
Vertical track angle | 23° |
Vertical tracking force | 1.8g to 2.2g (standard: 2g) |
Stylus mounting | Nude square shank |
Recommended load impedance | 47000Ω |
Coil impedance | 3.3kΩ (1kHz) |
DC resistance | 485Ω |
Coil inductance | 550mH (1kHz) |
Output voltage | 3.5mV (@ 1kHz, 5cm/sec) |
Output channel balance | 1.5dB (1kHz) |
Stylus type | Shibata |
Cantilever | Aluminum pipe |
Static compliance | 20 x 10-6cm / dyne |
Dynamic compliance | 10 x 10-6cm / dyne (100Hz) |
Mounting | 1/2" centres |
Cartridge weight | 6.1g |
Recommended load capacity | 100-200pF |
Style size | 2.7 x 0.26mil |
Cartridge type | VM Stereo dual magnet |
Cable used for coil | T.P. Copper |
Dimensions (H x W x D) | 17.2 x 18.9 x 28.3mm |
Supplied accessories | 2x Mounting screws 11mm 2x Mounting screws 8mm 2x Washers Non-magnetic screwdriver |
