Refurbished product - Grade S
Cable drop of 3.7m.
Interconnect Cable OCC Copper Triple Shielding Ø9,2mm 3.7m
The Ramm Audio Elite8 is designed to provide the best possible analog connection to preserve the integrity of the transmitted signal. The result is a very low level of distortion and noise for a very transparent reproduction.
To achieve this result, the Elite8 incorporates geometrically organized OCC copper conductors with triple shielding and cotton filling. Each conductor is cryogenically treated to further improve transmission quality. It also uses the NBU (Noise Bypass Unit) technology with the use of a floating ground, which consists in separating the shield ground from the signal ground. The shield ground, connected only on one side, works like a Faraday cage, protecting the conductors from interference. A beautiful gold and black Nylon sheath finally dresses the cable, giving it excellent mechanical resistance and a beautiful design. This model is ideal for symmetrical connections.
| Specifications | |
| Product type | Interconnect cable |
| Conductors | OCC Copper |
| Cable diameter | Ø9.2mm |
| Triple shielding | Aluminum-Mylar + PP |
| External sheath | PVC |
| Cover sleeve | Braided Nylon |
| Color | Blanc and gold |
| Length | 3.7m |
| Diameter (mm) | 9.2 |
| Length (m) | 3.7 |
| Section (mm²) | N/A |
| Refurbished Grade | Grade S |
