Refurbished product - Grade S
This product is sold in the form of 2m offcut pieces of cable.
This cable allows the production of high quality digital audio USB models with noble materials. The conductors are PTFE insulated. The conductive part on 4 wires is made of OFC (Oxygen Free Copper) 4N (99.99%) silver plated.
This very well designed cable also includes cotton wire for a better mechanical resistance of the whole. A double shielding by copper braid and aluminum foil guarantees a high immunity to parasitic noises.
Moreover this cable has a rare specificity. The DATA wire and 5V voltage part are separated by shielding guaranteeing a low rate of parasitic noises between the conductors. A reason choice to design all affordable high level digital audio USB cable.
We recommend the following gold-plated USB plugs for better contact:
Characteristic and structure of the cable :
| Diameter (mm) | 7.8 |
| Number of conductors | 4 |
| Insulation material | PTFE |
| Section (mm²) | 0.50 |
| Conductors Plating (Cable) | Silver |
| Refurbished Grade | Grade S |
| Ground / Shielding | Yes |
