[GRADE S] TANG BAND W6-1721 Speaker Driver Midbass 50W 4 Ohm 88dB Ø16.5cm
Refurbished product - Grade S
The Tang Band W6-1721 low midrange driver is equipped with a 3.8cm voice coil, moved by a massive 1.4kg ferrite magnet. Its design allows it to achieve a very low level of second and third order harmonic distortion. This impressive motor is coupled to a paper diaphragm with a rubber surround, all supported by a cast aluminum frame.
Reference : 16048
Refurbished
110,00 €tax incl.
91,67 € tax excl.
New product, never used.
Tang Band W6-1721
Speaker Driver Midbass 50W 4Ω 88dB Ø16.5cm
Tang Band W6-1721 Haut-Parleur Bas Médium 50W 4Ω 88dB Ø16.5cm
Speaker driver typeMidbass
Nominal diameterØ16.5cm (6.5")
Power handlingRMS : 50W
Max : 100W
Impedance4Ω
Frequency response40Hz - 5000Hz
Sensitivity88dB @ 2.83V/1m
Voice coil diameterØ3.8cm
Thiele-Small parameters
Resonant frequency (Fs)40Hz
DC Resistance (Re)3.4Ω
Voice coil inductance (Le)0.084mH
Mechanical quality factor (Qms)3.58
Electromagnetic quality factor (Qes)0.49
Total quality factor (Qts)0.43
Compliance equivalent volume (Vas)1.04 ft.³
Mechanical compliance of suspension (Cms)1.058mm/N
Force factor (BL)5.12Tm
Max linear excursion (Xmax)8mm
Surface area of cone (Sd)139.9cm²
Materials
ConePaper
SurroundRubber
FrameCast aluminum
MagnetFerrite
Informations de montage
Overall outside diameterØ17.6cm (6.94")
Cutout diameterØ14.7cm (5.8")
Depth10.9cm (4.3")
Number of mounting holes4
Optimum cabinet size (Measured with Bass Box 6 Pro)
Sealed volume0.33ft.³
Sealed F379Hz
Vented volume1ft.³
Vented F342Hz
Refurbished GradeGrade S
Refurbished product - Grade S The Tang Band W6-1721 low midrange driver is equipped with a 3.8cm voice coil, moved by a massive 1.4kg ferrite...
