Refurbished product - Grade S
New product, never used.
Speaker Driver Midbass 50W 4Ω 88dB Ø16.5cm
The Tang Band W6-1721 low midrange driver is equipped with a 3.8cm voice coil, moved by a massive 1.4kg ferrite magnet. Its design allows it to achieve a very low level of second and third order harmonic distortion. This impressive motor is coupled to a paper diaphragm with a rubber surround, all supported by a cast aluminum frame.
Speaker driver type | Midbass |
Nominal diameter | Ø16.5cm (6.5") |
Power handling | RMS : 50W Max : 100W |
Impedance | 4Ω |
Frequency response | 40Hz - 5000Hz |
Sensitivity | 88dB @ 2.83V/1m |
Voice coil diameter | Ø3.8cm |
Thiele-Small parameters | |
Resonant frequency (Fs) | 40Hz |
DC Resistance (Re) | 3.4Ω |
Voice coil inductance (Le) | 0.084mH |
Mechanical quality factor (Qms) | 3.58 |
Electromagnetic quality factor (Qes) | 0.49 |
Total quality factor (Qts) | 0.43 |
Compliance equivalent volume (Vas) | 1.04 ft.³ |
Mechanical compliance of suspension (Cms) | 1.058mm/N |
Force factor (BL) | 5.12Tm |
Max linear excursion (Xmax) | 8mm |
Surface area of cone (Sd) | 139.9cm² |
Materials | |
Cone | Paper |
Surround | Rubber |
Frame | Cast aluminum |
Magnet | Ferrite |
Informations de montage | |
Overall outside diameter | Ø17.6cm (6.94") |
Cutout diameter | Ø14.7cm (5.8") |
Depth | 10.9cm (4.3") |
Number of mounting holes | 4 |
Optimum cabinet size (Measured with Bass Box 6 Pro) | |
Sealed volume | 0.33ft.³ |
Sealed F3 | 79Hz |
Vented volume | 1ft.³ |
Vented F3 | 42Hz |
