[GRADE B] VIBORG VE512R Schuko Type E/F Power Connector Silver / Rhodium Plated Pure Copper Ø20mm
-22%
Refurbished Product - Grade B
The VE512R serie power connectors are designed to for high quality power cables assembly.
They have a robust clamping system which ensures great stability from 6 to 20mm⌀ and are therefore quite suitable for HiFi cables with a large diameter.
Reduced price!
Reference : 22733
Refurbished
90,00 €tax incl.
-22%
69,90 €tax incl.
58,25 € tax excl.
Last items in stock !
Shipping date: 24-11-2026.
Insertion marks on the contacts.
VIBORG VE512R
A pure copper conductor with triple plating (respectively: OFC Copper, Silver and Rhodium) ensures superior conductivity that will enhance the qualities of a well-built power-supply, benefiting all subsequent elements of the installation.
Finally, the assembly is protected by a lightweight aluminum housing with a elegant design. This material also limit any EMI / RFI interference that might impair the signal.
Connector TypeSchuko male
Contact materialspure copper
Max cable diameter6-20mmØ
Plating contacts1. OFC copper
2. Silver
3. Rhodium
Max conductors dimensionsDiameter: 4.5mm
Section: 15.90mm²
AWG: 5
Voltage / CurrentAC 250V / 16A
Dimensions79.5x40mm / Length 98.6mm
ScrewHex / Phillips
ColorMoney
Max cable diameter (mm)20.0
Mounting typeTo screw
ConnecticMale
ConnectorPLug CEE 7/7
Rated current (A)16.0
Refurbished GradeGrade B
Refurbished Product - Grade B The VE512R serie power connectors are designed to for high quality power cables assembly. They have a robust...
