[GRADE A] DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Weatherproof 50W 8 Ohm 40He - 15kHz Ø10.2cm
-15%
Refurbished Product - Grade A
A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is screw-mounted using the screw head molded into the speaker.
Reduced price!
Reference : 22736
Refurbished
26,90 €tax incl.
-15%
22,90 €tax incl.
19,09 € tax excl.
Shipping date: 24-11-2026.
Original packaging box missing.
DAYTON AUDIO HDN-8
DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Waterproof 50W 8 Ohm 40He - 15kHz Ø10.2cm
A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is screw-mounted using the screw head molded into the speaker. It's ideal for applications where speakers can't be placed for visual reasons, or for outdoor locations, or for vandal-proofing. In fact, thanks to its hermetically sealed design, it can be easily integrated into an indoor bathroom or outdoor terrace. The large-thread metal stud is easy to install in wood, fiberglass or plastic. This product can be used like a conventional loudspeaker, thanks to its 8-ohm impedance.
KEY POINTS :
  • Rugged plastic housing with black matte finish
  • Coarse-threaded mounting stud for single-point mounting into almost any material
  • Hermetically-sealed design for installation in wet or humid environments
Technical charcteristics
Product typeSound Exciter
Output power50Wrms
Impedance8Ω
Fréquency response40Hz-15kHz
Weatherproof
Net weight1kg
DimensionsØ100 x 50 mm
Package1x DAYTON AUDIO HDN-8 Speaker Driver Exciter
Speaker Power (W RMS)50.0
Speaker TypeExciter
Impedance (Ω)8
Loudspeaker diameter (mm)102.0
Diaphragm typeN/A
Max Linear Excursion (Xmax) (mm)N/A
Lowest frequency (Hz)40
Highest frequency (Hz)15000
Refurbished GradeGrade A
Refurbished Product - Grade A A weatherproof electrodynamic exciter that can be placed virtually...
