Les appareils IEAST ne supportent pas le format .OGG
dommage !!
Refurbished product - Grade A
Box slightly damaged. Very slight marks on the edges of the product.
This compact WiFi audio streamer / receiver allows you to listen to music on your HiFi system directly from your Smartphone, tablet, computer, or other DLNA / AirPlay / UPnP compatible source. The iEast receiver has WPS technology, allowing you to connect to the WiFi network in a simple, fast and secure way. The WPS button on the case allows you to access this option. You can also connect it via its RJ45 Ethernet port, free to choose according to your preferences.
With a 3.5mm Stereo Jack and a Toslink Optical Output, you can easily connect it to your HiFi or audio amplifier to listen to music up to 24 bit / 192kHz .
This product also allows playback of audio files via its USB-A input, up to 1TB.
Equipped with audiophile components such as an ESS ES9023 Sabre DAC , it will fit perfectly with your HiFi system.
The remote controlc allows you to select the song, manage the volume, and play or pause music when the receiver is in the file player (USB) mode. It also allows you to turn the iEast off and on, as well as select the previously configured quick access list (see operating instructions).
An iEast Play app is available on Android and iOS. It allows you to access music stored on your Smartphone, on your NAS (Synology, QNAP, etc.) ... in short, centralization of your music libraries on a single dedicated application and to easily manage the multiroom.
The iEast Audio / Streamer Receiver has been tested by Qobuz, you can read their test by following this link:
(Namely that Qobuz is natively supported by the iEast application, and is available in the settings on the iOS application)
You will find in the attached file below, a complete user manual of Streamer iEast.
The Streamer iEast is compatible with all these music services:
Features:
Strong points :
Specifications:
Connectors:
Packaging:
- iEAST VS Bluetooth, and other technologies -
Input | Jack 3.5mm |
Input | WiFi |
Input | RJ45 |
Output | Optical Toslink |
Output | Jack 3.5mm |
DAC / ADC Chip | ES9023 |
Max sampling rate | 192kHz |
Color | Black |
Streaming services & Network protocols | Qobuz |
Streaming services & Network protocols | Web radios |
Streaming services & Network protocols | AirPlay |
Streaming services & Network protocols | Tidal Connect |
Streaming services & Network protocols | Deezer |
Streaming services & Network protocols | Tidal |
Streaming services & Network protocols | DLNA |
Streaming services & Network protocols | Spotify Connect |
Streaming services & Network protocols | Spotify |
Refurbished Grade | Grade A |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
