[GRADE A] IFI AUDIO GND DEFENDER Main Power Supply Ground Loop Filter 90-240VAC
Refurbished product - Grade A
The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender intelligently detects the presence of a ground loop and corrects it.
Reference : 17256
129,00 €tax incl.
107,50 € tax excl.
Damaged packaging.
iFi Audio GND Defender Filtre d'Alimentation Secteur Boucle de Masse 90-240V AC
The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can create low frequency hum. The GND Defender intelligently detects the presence of a ground loop and corrects it. The crossover plugs directly and easily into the IEC connector of your device. It also incorporates EMI shielding to limit external interference.
Product typeMain power supply filter for ground loop
Voltage rating90-240V AC
Continuous current10A (1100W - 2400W)
Surge overload rating220A
Dimensions68 x 37 x 32mm
Weight61g
ColorWhite
Rated current (A)10.0
Refurbished GradeGrade A
Refurbished product  - Grade A The iFi Audio GND Defender is a power supply filter, which eliminates ground loops. A ground loop can...
