[GRADE S] MINIDSP 2x4 HD Interface / IIR Crossover / DAC 24bit 96Khz
Refurbished product - Grade S
The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 192khz DAC (digital / analog converter) with SPDIF Toslink & asynchronous USB Audio Class 2.0 inputs. As most of miniDSP devices, 2x4 HD provides powerful, accessible tools to implement a digital filter (IIR Butterworth / Linkwitz Riley 6 to 48dB) and a parametric equalizer. It will suit audiophiles who want to set an effective correction on a pair of stereo speaker.
Reference : 16374
249,00 €tax incl.
207,50 € tax excl.
Product reconditioned by the manufacturer. Perfect condition
MiniDSP 2X4 HD Interface
IIR digital filter / DAC 24bit 96Khz
The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 192khz DAC (digital / analog converter) with SPDIF Toslink & asynchronous USB Audio Class 2.0 inputs. As most of miniDSP devices, 2x4 HD provides powerful, accessible tools to implement a digital filter (IIR Butterworth / Linkwitz Riley 6 to 48dB) and a parametric equalizer. It will suit audiophiles who want to set an effective correction on a pair of stereo speaker. The device can also be used to manage multiple subwoofers in a home theater setup.
In addition to its digital input, the 2x4 in miniDSP has a stereo analog input on RCA connector for connecting another Hi-Fi device with analog output. Such as a turntable via a RIAA box, or any other analog source. It is a great accessory to centralize the whole installation on a single pair of speakers, while enjoying a correction / filter that extends to the entire chain.
Interface presentation
Plug-in miniDSP 2x4 HD
Processor capacity with FIR and IIR ADSP12489:
The computing power of the Analog Device ADSP12489 processor floating point calculation allows management of finished impulse response FIR type allowing linear curves digital adjustments with high precision. One can thus use the type of conventional technology IIR and FIR according to one's specific need for optimal results.
The MiniDSP 2X4 HD is a Swiss Army knife of digital analog digital filter providing a complete solution with USB / SPDIF input / analog parametric equalizer.
IR Remote Control for dsp
IR remote
Thanks to its remote learning function, this Audio miniDSP processor is compatible with a wide range of IR remote control.
We recommend this model of IR remote which supports 38 Khz NEC (works with virtually with all miniDSP devices and even with streamer based on RPI)
Inside view
This product is also available as a module (bare PCB as presented above) for the purpose of custom integration.
You can upgrade this device into a DDRC-24 by buying a DIRAC LIVE licence at MiniDSP. to find the whole process and buy a licence. Go to this webpage (miniDSP website) if you ever need to upgrade your 2x4HD.
TypeDigital filter
DAC
USB interfaceXMOS X200
ADC / DAC24 bit
ControlRemote control (not included)
Windows PC interface (requires Adobe Flash, Adobe AIr & Net Framework)
Digital inputsUSB Input: Windows-compatible ASIO 24bit 192khz asynchronous
digital SPDIF Toslink with asynchronous processor ASRC (20-216Khz)
Analog inputsanalog stereo input RCA phono level of 2V input (or 4V by jumpers)
analog input impedance 10KOhm
0003 THD, 103dB dynamic
Analog outputs4 analog outputs on RCA phono connectors
2Vrms Output Level
Output Impedance 560 Ohm
THD 0.001%
Power supply12V VDC connector 5.5 / 2.1mm (2.5W) - Power supply provided
Dimensions27 x 119 x 107mm
Package Contents
Interface miniDSP 2x4HDx1
12V adapter plug UK / EU / US / AUx1
Shielded USB cablex1
Code to download the plug-in 2 x 4x1
Max sampling rate96kHz
Refurbished GradeGrade S
Refurbished product - Grade S The MiniDSP 2X4HD interface is a processor for digital filtering. It uses a 24 bit / 192khz DAC (digital / analog...
