By buying this product you get 139 loyalty points
Refurbished product - Grade S
Product in perfect condition. Previous version.
Power Amplifier PURIFI 1ET400A 2x400W 4 Ohm
We are proud to present AUDIOPHONICS HPA-S400ET, a class D stereo power amplifier based on two PURIFI 1ET400A modules. This ready-to-use version is designed for audiophiles needing a foolproof amplification solution, with a considerable power reserve as well as impeccable linearity. The PURIFI modules are indeed among the most rigorous Class D amplification solutions on the market, with simply exceptional measured performance.
This device offers high level sound reproduction which will be suitable to drive demanding speakers, to sonorize large listening rooms or for studio applications requiring a considerable headroom without compromising on the precision and richness of the audio message.
All of the components are integrated in a sober and robust 100% Aluminum housing with openings and heatsinks to help heat dissipation. Its design also allows it to block signal interference.
The SMPS1200 switching power supply is a model with very high maximum output power of 1200 Watts. It has been specifically designed and developed by Hypex to provide 2 x 64V voltage required for operation of the most demanding amplifier modules.
This low noise high quality Power supply, meets every energy needs of the amplification modules.
Both modules are driven in opposite phase, to cancel out the «Power-Supply Pumping» effect. This allows greater stability in the power supply by alternately distributing current draws on each rail, thus increasing its overall capacities.
We opted for a two stage voltage regulation in order to optimize the power supply to the OPAs and the auxiliary voltage supplied to the modules.
A Texas Instrument LM4562 OPA per channel is used, these are very low distortion AOPs offering the greatest transparency with a very low THD. They are mounted on socket allowing their replacement if necessary
To suit all uses we opted for 3 gain settings, adjustable by jumper on the interface board.
Designed for easy integration, the HPA-S400ET has a balanced stereo (XLR) and unbalanced (RCA) input. Bipolar selectors make it easy to change the input source and even allow independent channel control.
On output side, BP-207 Carbon / Gold 24K Ø5.5mm speaker terminals ensure excellent connection with the speakers.
A trigger module allows the amplifier to be switched on automatically from a distance. This is compatible with voltages from 5 to 12V.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
" The Audiophonics HPA-S400ET comes in a beautiful package with super performance to match its good looks. Yes, it builds on Purifi's excellent platform but they managed to add value without messing with its performance. The gain settings are well thought through. The whole thing is so well executed and must be a delight to our European members who can buy it locally. Having been built in France, it is also a feather in the cap of our French members. I am happy to give my strongest recommendation to Audiophonics HPA-S400ET. You have a lot of power with superb fidelity and transparency. "
Type | Power Amplifier |
Output power (max) | 8Ω @1%THD : 227W 4Ω @1%THD : 425W 2Ω @1%THD : 450W |
THD+N | PO=1W, f=1kHz 0.0007 % PO=10W, f=1kHz 0.00026 % PO=100W, f=1kHz 0.00015 % PO=1W, f=20-20kHz 0.0007 % PO=10W, f=20-20kHz 0.00029 % PO=100W, f=20-20kHz 0.00017 % |
IMD (CCIF) | PO=1W, f=18kHz+19kHz 0.00025 % PO=10W, f=18kHz+19kHz 0.00022 % PO=100W, f=18kHz+19kHz 0.00027 % |
IMD (DIM) | PO=1W, DIM30 0.002 % PO=10W, DIM30 0.002 % PO=100W, DIM30 0.002 % |
Idle noise | A-weighted 11.5 µV |
Dynamic range | A-weighted 4Ω 131 dB |
SNR | A-weighted 4Ω 131 dB |
Frequency response | RL= 8Ω, f= 20-20kHz ±0.01 dB RL= 4Ω, f= 20-20kHz ±0.01 dB RL= 2Ω, f= 20-20kHz ±0.01 dB |
Output impedance | 1kHz, Iout=1A 0.07 mΩ 20-20kHz, Iout=1A <0.65 mΩ |
Input impedance | RCA: 47kΩ / XLR: 94kΩ Bypass: 2.2kΩ / 4.4 kΩ |
Power supply | 110V-230V (selector switch on the underside of the housing) |
Dimensions | 413 x 322 x 60mm |
Weight | 5.63 kg |
Power cable | Included |
Input | XLR |
Input | RCA |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Class | Class D / T |
Amplifier chip | Purifi 1ET400A |
Power (W) | 400.0 |
Remote Control | No |
Refurbished Grade | Grade S |
