[GRADE A] FIIO SR11 Streamer Black
-10%
Refurbished product - Grade A
FiiO's SR11 network player is a compact, high-performance streamer designed to work in conjunction with the K11 DAC/headphone amplifier. Based on an X2000 processor, it is compatible with numerous network protocols such as Airplay and Roon Ready, thanks to its WiFi 2.4/5GHz receiver.
Reduced price!
Reference : 21062
Refurbished
99,00 €tax incl.
-10%
89,00 €tax incl.
74,17 € tax excl.
Last items in stock !
Shipping date: 26-08-2025.
Torn cardboard packaging.
FiiO SR11 Streamer WiFi Airplay Roon Ready 32bit 768kHz DSD256 Black
FiiO SR11 picture
FiiO's SR11 network player is a compact, high-performance streamer designed to work in conjunction with the K11 DAC/headphone amplifier. Based on an X2000 processor, it is compatible with network protocols such as Airplay 1 and Roon Ready, thanks to its WiFi 2.4/5GHz receiver. This means you can enjoy a wide range of digital sources, whether via your smartphone, your computer or a local network, from a NAS. Simple to use, this little device acts as a veritable gateway between your streaming services and your sound system. It features numerous digital outputs, including a USB-C output, a USB-A port (host and output), a coaxial SPDIF output and a Toslink optical output. The FiiO SR11 supports high-resolution PCM 32bit 768kHz and DSD DoP256 streams via its USB outputs.
Please note that the SR11 does not have a USB DAC function.
New V630 firmware available on FiiO.com
"The new firmware for SR11 has been officially released with new features such as local playback, Bluetooth reception, and DLNA support to meet the needs of most users."
FiiO SR11: Airplay 1 and Roon Ready
The FiiO SR11 supports the AirPlay network protocol, so you can easily connect your IOS devices. AirPlay supports streaming from Apple Music, FiiO Music, Spotify and Tidal. Roon Ready, meanwhile, gives you access not only to online services, but also to your music library on a local NAS server.
Protocoles AirPlay et Roon Ready
FiiO SR11: high-performance components
Processeur X2000
X2000 processor
The multi-core X2000 processor provides real-time control of the SR11 and fast, stable audio signal processing with low power consumption.
Module WiFi AP6256
AP6256 WiFi module
The ethernet port supports speeds of up to 1000Mbps for smooth, fast transmission, while the WiFi module supports dual-band WiFi 2.4Ghz and 5Ghz for extremely stable wireless transmission without data loss.
FiiO SR11: LCD display
The SR11's LCD screen displays essential operating information, such as selected mode, network status and volume level. The small potentiometer, also located on the front panel, enables a wide range of control actions. An infrared remote control is also supplied for remote control and an enhanced user experience.
FiiO SR11 display overview
FiiO SR11: firmware updates planned
FiiO's R&D team is proposing firmware updates for the evolution of the SR11 with new features: Bluetooth reception, FiiO Link, etc.
Update firmware FiiO SR11
FiiO SR11 overview
FiiO SR11overview
1USB-C power port (5V 2A DC)
2USB-C output
3Reset button
4USB-A port (host and output)
5WiFi antenna
6Toslink optical output
7Coaxial output
8RJ45 Ethernet port
Product typeStreamer
ProcessorX2000
WiFi moduleAP6256
Ethernet transceiverYT8531C
InputsNetwork
1x USB-A Host
Outputs1x USB-C output
1x USB-A output
1x Coaxial
1x Optical Toslink
WiFi2.4G/5G dual band (802.11 b/g/n/ac)
Ethernet speedUp to 1000Mbps
Supported network protocolsAirPlay 1
Roon Ready
Supported sampling ratesUSB: 32bit 768kHz, DSD DoP256
Optical Toslink / Coaxial: 24bit 192kHz, DSD DoP64
AirPlay reception: all streams are converted to 16bit 44.1kHz before output
MQA supportOn all outputs with fixed volume
Digital output distortion0.000006% (0dB, 1kHz, 24bit 192kHz)
ScreenLCD
LED indicatorBlue: 48kHz and less
Yellow: 48kHz and more
Green: DSD
MAJ FirmwareVia USB flashdisk (USB-A and USB-C)
Power supply5V 2A DC via USB-C
Dimensions157 x 133 x 32mm
Weight375g
Package1x FiiO SR11
1x IR remote control
1x AC adapter with USB-A to USB-C cable
InputRJ45
InputWiFi
OutputOptical Toslink
OutputUSB
OutputCoaxial SPDIF
DAC / ADC ChipNC
Max sampling rateDSD256
Max sampling rate768kHz
Remote ControlYes
Streaming services & Network protocolsRoon / Roon Bridge / Roon Ready
Refurbished GradeGrade A
[GRADE A] FIIO SR11 Streamer WiFi Airplay Roon Ready 32bit 768kHz DSD256 Black
Refurbished product - Grade A FiiO's SR11 network player is a compact, high-performance streamer designed to work in conjunction with the...
