Balanced Regulated Phantom Power Supply Module 48V 5V +15/0/-15V
This regulated phantom power supply module is ideal for supplying 48 V DC power to a microphone. The module also provides additional 5V and -15/0/+15V outputs. This high-performance module is regulated by LM317, L78 and LM337T voltage regulators, providing your equipment with a clean, stable power supply. A switch makes it easy to switch the module on and off, and variable resistors can be used to adjust the various output voltages.
1 | Réglage sortie 48V |
2 | Switch ON/OFF |
3 | Réglage tension positive sortie -15/0/+15V |
4 | Réglage tension négative sortie -15/0/+15V |
5 | Sortie 5V |
6 | Sortie 48V |
7 | Sortie -15/0/+15V |
Product type | Regulated Phantom Power Supply Module |
Input voltage | 220V AC |
Output voltages | 48V DC (adjustable) 5V DC +15/0/-15V (adjustable) |
Intensity (output) | 48volts ......2ma +- 13.75volts .....150ma + 5 volts ....150ma |
Regulators | 2x LM317 1x LM337T 1x L78 |
ON/OFF Switch | |
Input connector | IEC C14 |
Dimensions | 148 x 91mm |
Fixation holes spacing | 119.5 x 84mm |
Weight | 440g |
Input | IEC C14 |
Output | Screw terminals |
Output voltage (V) | 48.0 |
Output voltage (V) | 5.0 |
Output voltage (V) | 15.0 |
Output current (A) | 2.0 |
Output current (A) | 0.1 |
Input voltage (V) | 220.0 |
Power Supply | Phantom power |
