IAN CANADA UCPURE PRO 43B Supercapacitor Power Supply Module Kit Class A 12V
New
The UcPure Pro from IAN Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance.
By buying this product you get 41 loyalty points
Reference : 21031
419,00 €tax incl.
349,17 € tax excl.
Ian Canada UcPure Pro 43BSupercapacitor Power Supply Module Kit class A 12V
Photo of IAN CANADA UCPURE PRO 43A
The UcPure Pro from Ian Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the huge 3000F or higher capacitance ultracapacitor pack to achieve an ultimate power supply performance. Because it is a pure passive power supply, there will be neither feedback nor active components involved when it’s turned on. At the pure mode, the output is 100% isolated from input, only the pre-charged ultracapacitor pack will be connected to the load.
UcPure Pro revolutionary employs triple PCB architecture to separate the management PCB from the ultracapacitor pack PCBs. The output will be taken directly from the ultracapacitor pack without charging or other circuits involved. Bolt-down automotive fuses are first time being used by UcPure Pro for higher reliability and lower ESR.
UcPure Pro could be the best low noise, low ESR pure power supply in world so far. Sound quality of sensitive audio applications such as low jitter clock oscillators, DACs, FIFOs, I/V stages and many other circuits will be benefited greatly from this UcPure Pro power supply.
Please note that supercapacitors are sold separately.
Ian Canada UcPure Pro 43B: Power module highlights
  • Triple PCB architecture makes it has the lowest ESR and noise levels among all UcPure generations.
  • Plate PCBs were developed to take the output directly from the ultracapacitor pack over much bigger double thickness multi-layers copper areas.
  • Ultracapacitor plate PCBs are separate from management PCB for a much purer working condition.
  • +/-5V or 12V or 3.3V or 5V configurations
  • 5V configuration has a USB-C output. Could the best low noise high quality USB power supply in the world.
  • Has both precision and normal output voltage range control mode
  • Precision balancers have been integrated on PCB, so no longer need external balancer/protection boards.
  • Configurable input current limitation to protect AC/DC input without affecting the peak charging current. Can also save cost by using lower rated current transformers.
  • 7.8A/10A high peak charging current, charge and re-charge ultracapacitors very fast
  • Ultra-high current/low ESR output terminal connector, ideal for big or groups of power wires
  • Optimized to AC input (12V AC for 3.3V, 5V, +/-5V configuration or 15V AC for 12V configuration), can also work with 15V to 19V DC input.
  • Manual charging triggering push-button option
Product typeSupercapacitor power supply module
Input voltage15V AC for 12V configuration or 15V to 19V DC
Output voltage12V
Compatible capacitorsXL60-2R7308T-R ou TPLH-2R7/3000SL60138 for all configurations except 12V
XL60-3R0308T-R ou TPLH-3R0/3000SL60138 for 12V and all other configurations
Package1x Ian Canada UcPure Pro 43B (12V)
InputJack DC 5.5/2.5mm
InputScrew terminals
OutputScrew terminals
OutputPCB Connector
Output voltage (V)12.0
Output current (A)10.0
Input voltage (V)15.0
Power SupplyUltracapacitor power supply
The UcPure Pro from IAN Canada is part of the third generation of supercapacitor power supplies designed by the brand. It makes use of the...
