Power Supply Board LT1764A +/-15V 2x15V 5V
This versatile power supply module provides two 15V outputs or one +/-15V output depending on the wiring, as well as a 5V output. The voltage of each output is adjustable, from 5V to 20V for the former and from 3.3V to 5V for the latter.
Reference : 15181
24,90 €tax incl.
20,75 € tax excl.
Power supply board
LT1764 +/-15V 2x15V 5V
Module d'alimentation< LT1764 +/-15VAC 2x15VAC 5VAC
This versatile power supply module provides two 15V outputs or one +/-15V output depending on the wiring, as well as a 5V output. The voltage of each output is adjustable, from 5V to 20V for the former and from 3.3V to 5V for the latter. The module achieves low noise and ripple thanks to the use of LDO LT1764 regulators. The input is done on two 12V inputs and/or on one 9V input. The module also integrates a short-circuit protection at the output and a thermal protection.
For a dual 15V output, it is recommended to use a dual toroidal transformer with 12V outputs.
For a 5V output, it is recommended to use a toroidal transformer with 6V output to limit the voltage difference between input and output.
Product typePower supply board
Inputs2x 12V AC
1x 9V AC
Outputs2x 15V OR +/-15V DC (adjustable 5~20V)
1x 5V DC (adjustable 3.3~5V)
LDO RegulatorsLT1764
ProtectionsShort circuits
Thermal protection
Max current2A
Dimensions80 x 75mm
Mounting holes spacing73.5 x 68mm
InputScrew terminals
OutputScrew terminals
Output voltage (V)5.0
Output voltage (V)15.0
Output current (A)2.0
Input voltage (V)12.0
Input voltage (V)9.0
Power SupplyRegulated Linear Power Supply
En observant cette alimentation, on peut voir que chaques détails a été pensés. Qualité extréme ! Méme la couleur du circuit imprimé ( noir ) n'a pas été choisie au hasard. Excellent !!!
This review has been posted for Power Supply Board LT1764A +/-15V 2x15V 5V
This versatile power supply module provides two 15V outputs or one +/-15V output depending on the wiring, as well as a 5V output. The voltage of...
