Power Supply DC-DC Converter Module 4-12V DC to +/-8 to +/-18V DC 1.5A
This small regulated power supply module acts as a DC-DC converter. It is indeed able to take a voltage of 4V to 12V DC as an input and then output an adjustable voltage ranging from +/-8V DC to +/-18V DC. By default, the module is set to an output voltage of +/-12V DC.
4.0 / 5
Reference : 14008
9,90 €tax incl.
8,25 € tax excl.
POwer Supply Module
Module d'alimentation Convertisseur DC-DC 4-12V DC vers +/-8 à +/-18V DC 1.5A
This small regulated power supply module acts as a DC-DC converter. It is indeed able to take as input a voltage from 4V to 12V DC (5V DC on the Micro USB) and then output an adjustable voltage ranging from +/-8V DC to +/-18V DC. By default, the module is set to an output voltage of +/-12V DC. The module can be input either on a Micro USB connector (5V DC) or on solder contacts. The output is also to be soldered.
The quality design of the module, which includes low-loss inductors or high-frequency ceramic capacitors with very low resistance and connected in parallel, provides a clean and stable electrical signal, essential for precise and rich sound reproduction.
Product typeDC-DC Converter
Input voltage4-12V DC (5V DC on Micro USB)
Output voltageAdjustable from +/-8V to +/-18VDC (+/-12V DC by default)
Max output current1.5A
Input2 Contacts to solder
1x Micro USB (Max 5V)
Outputs3 Contacts to solder
Dimensions (LxPxH)41 x 41.4 x 15mm
Fixation holes spacing33 x 33mm
InputSolder pad
OutputSolder pad
Output voltage (V)10.0
Output voltage (V)13.0
Output voltage (V)9.0
Output voltage (V)17.0
Output voltage (V)16.0
Output voltage (V)8.0
Output voltage (V)11.0
Output voltage (V)15.0
Output voltage (V)14.0
Output voltage (V)12.0
Output voltage (V)18.0
Output current (A)1.5
Input voltage (V)6.0
Input voltage (V)8.0
Input voltage (V)10.0
Input voltage (V)12.0
Input voltage (V)4.0
Input voltage (V)7.0
Input voltage (V)9.0
Input voltage (V)11.0
Power SupplyVoltage converter
Pratique !
Très pratique pour alimenté en + et - avec une batterie ! Peu bruyante lorsqu'il n'y a pas de conversion ou une conversion de faible delta mais à vérifier avec des bancs de mesures labo. En tout cas pour tester des montages audio analogique, c'est parfait.
This review has been posted for Power Supply DC-DC Converter Module 4-12V DC to +/-8 to +/-18V DC 1.5A
This small regulated power supply module acts as a DC-DC converter. It is indeed able to take a voltage of 4V to 12V DC as an input and then output...
