Tolerance (%)
1 % - 5 %
Power (W)
0 - 250
Resistance (Ohm)
Resistors
Vincent B.
Bof
Shigeo I.
Couldn't be more satisfied
A flawless power amplifier. The extension of the sound and the precision of left-right imaging are excellent—especially in solo...
Shigeo I.
outstanding cost-performance!
Purchased together with the Audiophonics LPA-S450ET. Since the power amplifier has a balanced architecture, when used with...
Resistors
  • Wire wound resistors
    Wound resistors are essential components for audio and electronic circuits, offering greater precision and reliability in the management of electrical signals. Constructed with a resistive wire wound around an insulating core, these resistors are designed to withstand high powers while minimizing resistance variations due to temperature changes. Their robust design allows for efficient heat dissipation, making them ideal for applications where long-term stability and consistent performance are crucial. Whether you're working on amplifiers, filters or power circuits, wound resistors ensure precise regulation and optimum reliability. Discover our selection and find the right resistors to guarantee the performance and durability of your electronic projects.
  • Ceramic resistors
    Ceramic resistors
    Ceramic resistors are designed to deliver outstanding performance in demanding environments and high-power applications. Manufactured from high-quality ceramic materials, they provide excellent thermal stability and efficient heat dissipation, making them ideal for circuits requiring enhanced reliability and robustness. Their ability to withstand high temperatures and high currents without degradation makes them a preferred choice for amplifiers, audio filters and power circuits. Thanks to their low temperature coefficient, ceramic resistors guarantee consistent precision and increased durability. Explore our range of ceramic resistors and choose the components that best meet the requirements of your electronic and audio projects.
  • Film resistors
    Film resistors
    Film resistors are essential components for ensuring exceptional precision and stability in your electronic circuits. Constructed with a thin layer of resistive material deposited on a substrate, these resistors offer excellent regularity and low thermal drift, ideal for audio applications and high-precision circuits. Their careful design ensures low tolerance and rapid response to current variations, contributing to stable, reliable performance. Whether you're working on audio amplifiers, filters or measurement equipment, film resistors deliver consistent value and unrivalled sound clarity. Explore our selection to find the right film resistors to meet the specific needs of your electronic and audio projects.
