TELEGARTNER J00029A6000 Ethernet RJ45 Female Connector
This Telegartner Cat.6A female RJ45 connector allows you to design Ethernet extension cables. Installation is simple and does not require crimping pliers. The connector accepts cables with a diameter of up to 9 mm and conductors with a cross-section of 0.102 mm² (27 AWG) to 0.326 mm² (22 AWG).
Reference : 20895
9,90 €tax incl.
8,25 € tax excl.
Shipping date: 20-11-2026.
Telegartner J00029A6000 Ethernet RJ45 Cat.6A Female Connector Shielded Ø9mm
TELEGARTNER J00029A6000 : Front view
Product typeFemale RJ45 Cat.6A connector
Housing materialNickel-plated zinc
Shielding materialSilver
Max bandwidth10Gbps
Contacts platingGold
Maximum cable diameterØ9mm
Service life≥ 750 insertion / extraction cycles
Temperature range-40°C - +70°C
Dimensions32 x 21 x 15mm
PackageSold by unit
Max cable diameter (mm)9.0
Mounting typeTo connect
ConnecticFemale
ConnectorRJ45
Download
TELEGARTNER J00029A6000 Ethernet RJ45 Cat.6A Female Connector Shielded Ø9mm
This Telegartner Cat.6A female RJ45 connector allows you to design Ethernet extension cables. Installation is simple and does not require crimping...
