By buying this product you get 68 loyalty points
Schuko Wall Plug NCF with Fastening Connection System
The power supply of a high-fidelity device is the starting point of the signal that will later be transformed into sound. It is therefore imperative to take care of this section in order to enjoy a stable, clean signal and a perfectly secure connection. Block Audio offers with the C-Lock SE a high quality Schuko wall socket. It is equipped with Rhodium-plated contacts with NCF technology, ensuring excellent signal transmission.
But where the C-Lock SE really stands out is in its innovative, high-performance connection system. The plug is equipped with a ring that locks your cable to hold it firmly in position for a reliable connection that won't damage the plug, no matter how heavy your cable is. This technology also significantly reduces vibration.
In addition, the body of the plug made of Aluminum and will eliminate possible EMI interference that could alter the signal.
A technology developed by Furutech, NCF is based on a special crystalline material with two active properties. First, NCF generates negative ions that eliminate static electricity. Second, it converts thermal energy into infrared. Furutech combines this material with nano ceramic particles and carbon powder for their piezoelectric damping properties. Furutech thus obtains the optimal electrical and mechanical damping material.
Product type | Schuko wall plug |
Contacts material | Rhodium plated Copper |
Integrated technology | NCF |
Body material | Aluminum |
Compatible connector diameter | Ø32mm to Ø42mm |
Max cable diameter (mm) | N/A |
Mounting type | N/A |
Connectic | Female |
Connector | Schuko |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Rhodium |
Rated current (A) | N/A |
