Qualité vraiment au top pour ce bloc prise!
Rien que le poids en dit long!
Livré dans un petit coffret.
Gain significatif sur la propreté du signal! Un upgrade indispensable !
By buying this product you get 60 loyalty points
The wall outletFurutech FT-SWS-R NCFis a new version with a body using the technological advances of the brand (see NCF technology).
Following the recognized qualities of Furutech ceramic technical developments "Piezo Effect" with cushioning properties, here is a very high level wall outlet.
As with the other Japanese brand plugs, it receives the patented Alpha treatment which has made the reputation of Furutech.
The high quality of contact for this high-quality outlet is the essential accessory for Hifi High End systems requiring the utmost attention of implementation.
Moreover this plug is Rhodium plated for a high stability over time of the mechanical and electrical characteristics of this wall outlet Furutech.
It also has "claws" to be kept in a wall location.
Two other versions are available in Gold and Rhodium finish (without) NFC for a perfect adaptation to your High fidelity system:
Furutech FT-SWS-G (Gold version)
Furutech FT-SWS-R (version Rhodium)
NCF technology:
Incorporated in the new series of Furutech products, the NCF (Nano Crystal² Formula) consists of a special crystalline material that has two "active" properties.
TFirst, it generates negative ions that eliminate static electricity, but it also converts thermal energy into far infrared (LIR) whose wavelength varies from (50 μm to 5 mm).
Furutech combine then this remarkable material with nanometric ceramic particles and carbon powder for their "Piezo Effect" (damping properties).
The resulting Nano Crystal² (NCF) formula is the ultimate electric and mechanical damping material - (only available in Furutech products!).
Features:/ Strong>
Dimensions:
.jpg)
| Max cable diameter (mm) | 2.8 |
| Mounting type | To screw |
| Connectic | Female |
| Connector | Type F (CEE 7/3 - CEE 7/4) |
| Contacts Material (Connector) | Copper |
| Contacts Plating (Connector) | Rhodium |
| Rated current (A) | 16.0 |
Average votes 5.0 / 5 7 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
David G.
Edern C.
Philippe M.
Christophe V.
Jean-marc B.
