VIBORG VE02R Power Plug Schuko Type F Pure Copper Silver / Rhodium Plated 250VAC 16A
This Viborg VE02R Schuko plug uses very high quality materials to ensure a perfect transmission of the electrical signal. The contacts are made of pure Copper and benefit from a triple plating of OFC Copper, Silver and Rhodium.
Reference : 14735
63,85 €tax incl.
53,21 € tax excl.
Shipping date: 29-09-2026.
Viborg VE02R
Embase Schuko Cuivre Pur Plaqué Argent / Rhodium 250VAC 16A
Viborg VE02R Embase Schuko Cuivre Pur Plaqué Argent / Rhodium 250VAC 16A
This Viborg VE02R Schuko plug uses very high quality materials to ensure a perfect transmission of the electrical signal. The contacts are made of pure Copper and benefit from a triple plating of OFC Copper, Silver and Rhodium. This maximizes the conductivity of the connector, while ensuring excellent resistance to oxidation for maximum durability. The insulating body of the connector is made of Nylon with Fiberglass. The panel covering the plug is made of Aluminum, a robust and stylish design. The assembly is extremely simple thanks to a screwing system, without the need for soldering. The socket accepts cables up to 5mm diameter.
Product typeSchuko plug
Connector typeFemale Schuko
2 poles + ground
Voltage / Current250VAC / 16A
Contacts materialPure Copper
Contacts platingOFC Copper
Silver
Rhodium
Insulation materialNylon with fiberglass
Panel materialAluminum
Max cable diameterØ5mm
ConnectionTo screw (Hex screws)
Front panel holes spacing60mm
Total dimensions86 x 86 x 38mm
Max cable diameter (mm)5.0
Mounting typeTo screw
ConnecticFemale
ConnectorSchuko
Rated current (A)16.0
3 reviews
Le courant passe.
Prise très qualitative, c'est du sérieux et c'est aussi du lourd, ça pèse, la plaque frontale est très épaisse aidant probablement à une réduction des ondes électromagnétiques. L'arrière de la prise n'est pas plus profond qu'une prise Legrand standard. Les borniers sont assez grand pour accueillir chacun 2 fils de 2,5mm² (voir plus). Concernant le son, l'apport est indéniable, on perçoit une scène sonore plus profonde, la micro dynamique est améliorée, des micros informations apparaissent, les voix sont mieux incarnées. Il faut attendre quelques jours en laissant les appareils allumés pour que tout s'installe complètement. Je n'ai pas essayé les prises japonaises, mais le rapport qualité/prix de celle-ci est excellent. (Cable Furutech Empire, Furutech TP80ES NCF, Chrord Qutest, Primaluna Dialogue II, Cabasse Sampan 311/13.
This review has been posted for VIBORG VE02R Power Plug Schuko Type F Pure Copper Silver / Rhodium Plated 250VAC 16A
nice
arrived today and it has a real quality perception
Très bon produit, montage facile , vis type Allen avec clef fournie
Prise lourde et solide 5 * avec plaisir
This Viborg VE02R Schuko plug uses very high quality materials to ensure a perfect transmission of the electrical signal. The contacts are...
