SMSL SAP-9 Full Balanced Headphone amplifier 2x TPA6120A2
Reference : 11556
109,00 €tax incl.
90,83 € tax excl.
SMSL after sales service return product. New product, box slightly damaged.
Here is the brand new SMSL SAP-9, a headphone amplifier at symmetrical output which is the culmination of a long search of the brand's engineers. 2 amplification chips TPA6120A2 were used, so the amplification circuit separates the 2 right and left channels well.
In order to create a balanced circuit with zero noise and an extremely clean sound, the latter has a completely independent architecture and tracking. The volume control of this headphone amplifier will be done in the best digital way.
The SAP-9 SMSL offers you a connectors extended. In analog inputs, you will have the balanced stereo XLR port as well as the gold-plated stereo RCA port. In analog outputs you will have a 6.35mm jack headphone jack, a 2.5mm 4-pole balanced jack, as well as to complete the 4-pole balanced XLR headphone output her too.
Main Features :
  • Amplification chip: 2x TPA6120A2 (Datasheet can be downloaded below)
  • Signal to noise ratio: 110dB
  • Balanced XLR input / output: Zero noise and its own
  • Symmetric circuit architecture COMPLETE Independently Owned
  • Digital Control of volume
Output characteristic not symmetrical (THD + N = 0.1%):
  • 32 Ohm - 175mW
  • 64 Ohm - 130mW
  • 150 Ohm - 78mW
  • 300 Ohm - 45mW
Symmetrical output characteristics (THD + N = 0.1%):
  • 32 Ohm - 373mW
  • 64 Ohm - 342mW
  • 150 Ohm - 245mW
  • 300 Ohm - 155mW
Connectors:
  • RCA Stereo Plated Gold Input
  • Balanced XLR stereo input
  • Headphone Jack Jack 6.35mm
  • Headphone output Jack 2.5mm 4-pole symmetrical
  • Headphone output XLR 4-pole symmetrical
Dimensions / Weight / Power supply:
  • Dimensions: 121x120x36mm
  • Weight: 443g
  • Power supply: 5V / 2A DC (AC power adapter included)
  • Power Consumption: 7.2W
Amplificateur casque entièrement symétrique 2x TPA6120A2
SMSL SAP-9 Headphone amplifier
InputXLR
OutputJack 6.35mm
OutputJack 2.5mm
Mieux que sans lui.
Je voulais savoir, les câbles symétriques sont chers, les amplis symétriques sont rares, ... bref, ce modèle très abordable et une occasion sur un câble symétrique pour mes HD-600 (j'en possède 2 exemplaires) étaient une bonne solution pour mettre le pied dans ce domaine.
Je ne suis pas déçu du tout !
la pêche, l'image (plus ample, plus détaillée), tout y gagne.
mon système casque est basé sur un carte Focusrite. j'utilise la sortie casque pour l'un et les sorties symétriques (jack) de la carte pour l'autre avec ce petit ampli.
et c'est très très bien.
pas une révolution, mais un bond en qualité sensible.
pour le prix, si vous avez un casque qui peut se symétriser facilement, tentez le coup !
le sérieux Audiophonics est un plus bien sympa.
This review has been posted for SMSL SAP-9 Full Balanced Headphone amplifier 2x TPA6120A2
