NOBSOUND P32 Tube Headphone Amplifier
The Nobsound P32 is a tube headphone amplifier delivering an output power of 1000 mW into 32 Ω, compatible with headphones with an impedance of 24 to 600 Ω. Its tube stage provides a warmer sound, while the signal-to-noise ratio of ≥ 110 dB and the frequency response of 20 Hz to 30 kHz preserve the accuracy and stability of the listening experience.
Reference : 22509
46,90 €tax incl.
39,08 € tax excl.
Shipping date: 24-11-2026.
NOBSOUND P32 6J5 Tube Headphone Amplifier
NOBSOUND P32: Front view
Designed to evolve with the system, the P32 features interchangeable tubes and operational amplifiers, allowing its sound signature to be gradually adjusted without replacing the unit. This architecture thus combines headphone amplification, sound customization and a preamplification function within a single device.
Nobsound P32: 1000mW Tube Amplification
The Nobsound P32 is a tube headphone amplifier delivering an output power of 1000 mW into 32 Ω. Compatible with headphones with an impedance between 24Ω and 600Ω, it can drive both sensitive earphones and high-impedance models while maintaining a dynamic sound. Its tube stage provides a warmer sound signature, while the signal-to-noise ratio of ≥ 110 dB and the frequency response of 20Hz to 30 kHz help maintain a detailed and quiet listening experience.
NOBSOUND P32: Interchangeable OP-AMP
Nobsound P32: Sound Signature Customization
The tubes and operational amplifiers of the Nobsound P32 are interchangeable, allowing the sound to be gradually adapted to the components used. This scalable design offers the possibility to explore different sound signatures without replacing the entire unit, while keeping the same amplification and preamplification platform.
Technical specifications
Inputs1x Jack 3.5mm
1x RCA stereo
Outputs1x Headphone output Jack 3.5mm
1x Headphone output Jack 6.35mm
Frequency response20Hz-30kHz
SNR≥ 110dB
Matched headphone impedance24-600Ω
Output power≥1000mW (32Ω)
Output voltage swing24V
Supply voltage5V DC / 2A
Dimensions78 x 82 x 32mm
Weight220g
Package1x Nobsound P32
2x 6J5 Tubes
1x Power adapter
InputJack 3.5mm
OutputJack 6.35mm
OutputJack 3.5mm
ClassTube amp
The Nobsound P32 is a tube headphone amplifier delivering an output power of 1000 mW into 32 Ω, compatible with headphones with an...
