CS8416 Source Selector Module 2 SPDIF Inputs to 1 I2S Output
This module is an input module with a coaxial input and an optical input. It is based on a Cirrus Logic CS8416 digital audio receiver supporting sample rates up to 192kHz. The module is equipped with a 24bit I2S output which can therefore be associated with the I2S input of your DAC and offer it a source selection.
Reference : 12940
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 22-05-2025.
Input module
Input module SPDIF to I2S
Module Sélecteur de source CS8416
The module comes with a switch that will allow you to choose your source between Coaxial and Optical.
Power supply wiring
SPDIF interface card power supply
SPDIF ReceiverCirrus Logic CS8416
InputsCoaxial
Optical
OutputI2S
Supported sampling rate / bitrateSPDIF inputs : 32bit 192kHz
I2S output : 24bit
MCLK output256FS
Power SupplyDC 5-12V
Output signal voltage3.3V
ControlInput selection with included switch
Input selector module dimensions50 x 50 x 23mm
OutputI2S
Not for Raspberry Pi
The quality of the product is good, that`s why I give it 5 stars, but unfortunatelly it doesn`t work with Raspberry Pi/Audiophonics ES9038Q2M. If you want to have an optical or coaxial S/PDIF input in your DIY streamer, then just buy an optical/coaxial spdif socket and connect it to spdif + ground pins (+5V for optical socket) on Audiophonics DAC. You must also take into account the necessity of adding two capacitors to avoid "reloading" effect (lags in audio via optical spdif input).
This review has been posted for CS8416 Source Selector Module 2 SPDIF Inputs to 1 I2S Output
This module is an input module with a coaxial input and an optical input. It is based on a Cirrus Logic CS8416 digital audio receiver supporting...
