MUNDORF VN300 Zero Ohm Self Coil 12mH
By buying this product you get 25 loyalty points
Reference : 14141
259,00 €tax incl.
215,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Mundorf VN300 12mH
Zero Ohm Self Coil
Mundorf Self Bass Woofer Sub
Zero ohm coil ""Zero Ohm Coil"" (ZOC) is a coil transformer format.
It is made of FERON, a material with high electronic qualities that minimizes induced distortions.
The central spot of a ZOC is calibrated and adjusted by hand between two laminar rings (a L-shaped and a E-shaped).
The volume of the central space determines the inductance of the coil which demands enormous precision in the manufacturing process to ensure there will be no saturation at high load.
These coils are especially suitable for filtering your bass speakers. Their low impedance improves the impulse response (better light Speaker).
Dimensions
Dimensions Mundorf Zero Coil
All dimensions are given in millimeters (mm)
Inductance12mH
Tolerance5%
coil wire diameter3.00mm
CoreFeron
MaterialOFC 99.99% pure
Dimensions130 x 115 x 97
Inductance (mh)12.0
