HIFIBERRY AMP2 Amplifier Board Stereo TAS5756M Class D for Raspberry Pi 2x20W 4 Ohm
The HiFiBerry AMP2 is a small Class D stereo amplifier module for Raspberry Pi. It allows to develop a power of 2x18W under 4Ω. Conveniently, the AMP2 powers the Raspberry Pi itself, so the latter does not need to be powered independently.
Reference : 15647
69,90 €tax incl.
58,25 € tax excl.
HiFiBerry AMP2
Amplifier Board Stereo Class D for Raspberry Pi 2x20W 4 Ohm
HiFiBerry AMP2 Module Amplificateur Stéréo Class D 2x18W 4Ω
A 12-18V power supply is recommended for use with 4Ω speakers. A higher operating voltage is only recommended for 8Ω speakers. In all cases, 18V is still the recommended supply voltage.
If your playback software does not offer AMP2 as an output option, you can select the HiFiBerry DAC+ driver.
Product typeAmplifier module
Amplifier chipTAS5756M - Class D
InputGPIO 40 pins
OutputSpeaker terminals
ChannelsStereo (2)
Output power (RMS)2x14W @ 12V, 4Ω, THD+N < 0.1%
2x18W @ 18V, 4Ω, THD+N < 0.1%
2x20W @ 24V, 4Ω, THD+N < 0.1%
2x8W @ 12V, 8Ω, THD+N < 0.1%
2x17W @ 18V, 8Ω, THD+N < 0.1%
2x28W @ 24V, 8Ω, THD+N < 0.1%
THD+N< 0.02%
SNR104dB
Supported sampling ratesPCM up to 24bit 192kHz
Supply voltage12-24VDC (power supply sold separately)
Dimensions9 x 6 x 3cm
Weight60g
InputGPIO
The HiFiBerry AMP2 is a small Class D stereo amplifier module for Raspberry Pi. It allows to develop a power of 2x18W under 4Ω....
