By buying this product you get 33 loyalty points
Switching Mode Power Supply SMPS 1000W 12V 80A
Mean Well MSP-1000 switch mode power supplies provide high power output, up to 1000W, for a wide range of applications. The input voltage range is 90~264VAC and this model, the MSP-1000-12, provides an output voltage of 12V. In addition, the module is equipped with several functions, such as an auxiliary output and a remote ON-OFF function, as well as a complete safety system against overload, overvoltage and overheating.
| Specifications | |
| Product type | Switching mode power supply |
| Output power | 960W (max. 1000W during 3 sec) |
| Input voltage range | 90~264VAC 127~370VDC |
| Input frequency range | 47~63Hz |
| Efficiency | 91.5% |
| Output voltage | 12VDC |
| Output current | 80A |
| Ripple and noise | 150mVp-p |
| Protections | Overload (105~135% of rates output power) Over voltage (14.5~16.5VDC) Over temperature |
| General | |
| Dimensions | 218 x 105 x 63.5mm |
| Weight | 1.53kg |
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 12.0 |
| Output current (A) | 80.0 |
| Input voltage (V) | 100.0 |
| Input voltage (V) | 90.0 |
| Input voltage (V) | 120.0 |
| Input voltage (V) | 260.0 |
| Input voltage (V) | 210.0 |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 110.0 |
| Input voltage (V) | 370.0 |
| Input voltage (V) | 230.0 |
| Input voltage (V) | 220.0 |
| Power Supply | SMPS |
