SMPS300RS Switching Power Supply Module 300W / 32V
The SMPS300RS switching power supply is a very high performance model capable of developing a nominal power of 300 Watts in an extremely small footprint.
This power supply is capable of delivering 300W of continuous power and up to 400W peak.
The delivered version is a 32V.
The main feature of this power supply is the lack of radiators for both power switches and rectifier diodes.
The amount of EMI is less than any conventional power supply, and could be compared to a linear regulated power supply.
Its small size considerably reduced weight, allow to install the SMPS300RS everywhere.
The SMPS300R incorporates overcurrent protection that limits the output current to approximately 130% of maximum peak power, or about 400W. This power supply is suitable for both class AB and class D / T amplifiers.
• Download Datasheet SMPS300RE to PDF
Meaning of the terms R, RE, RS and RXE on alSMPS:
QR, R: SINGLE or DUAL power supplies with classical resonance filter LLC for amplifiers in class A / B or D, SMPS R are characterized by their ratio qualities price.
RE: SMPS power supplies with differential and multiple voltage outputs with resonant filter including an LLC filter with low noise EMI filter (with low ripple CLC filter) for class A / B or D / T class Amplifiers. Conveniently replaces conventional linear power supplies. (Generally suitable for TA2022, TDA8920, TDA8950, IRS2092 amplifiers)
RS: SMPS power supplies close to the RE but with a single rail output with a resonant filter including an LLC filter with low noise EMI filter (with low ripple CLC filter) for class A / B or D / T amplifiers . Advantageously replaces conventional linear power supplies.
RXE: The high-end SMPS 600, 800W and 2000W featuring the latest generation LLC resonant filters (with low-ripple CLC filter) with high-end FET transistors. Especially recommended for Class D high-end amplifiers (IRS2092, HYPEX, CXD). Can also be used for class A / B amplifiers.
Features:/ Strong>
Specifications:
| Input | Screw terminals |
| Output | Screw terminals |
| Output voltage (V) | 32.0 |
| Output voltage (V) | 12.0 |
| Output current (A) | NC |
| Input voltage (V) | 240.0 |
| Input voltage (V) | 95.0 |
| Input voltage (V) | 230.0 |
| Input voltage (V) | 110.0 |
| Input voltage (V) | 200.0 |
| Input voltage (V) | 220.0 |
| Input voltage (V) | 250.0 |
| Input voltage (V) | 120.0 |
| Input voltage (V) | 100.0 |
| Input voltage (V) | 190.0 |
| Input voltage (V) | 130.0 |
| Input voltage (V) | 210.0 |
| Power Supply | SMPS |
