Switching Power Supply Module 700W +/-40V
This LLC switch mode power supply module has a main output delivering ±40V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a clean power supply. The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A.
3.0 / 5
Reference : 15593
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 12-05-2026.
Module d'alimentation
Alimentation à découpage 700W ±40V
Module d'alimentation à découpage 700W ±30V
The power supply is also equipped with an independent output of 12V 0.5A and an auxiliary output of ±12V 0.5A. The latter allow the supply of less demanding devices, such as a fan. The module accepts an input voltage of 200-240V AC.
The module also benefits from a protection system against overheating, overcurrent and short circuits.
If a protection system is activated, the module locks up. It is then necessary to disconnect the AC power supply and wait for the filter capacitor voltage to drop to 0V before restarting.
The current of the independent and auxiliary outputs cannot exceed the current delivered by the main output.
Product typeSwitching power supply
Input200-240VAC on screw terminals
Output voltagesMain output : ±40V 6.5A
Independant output: 12V 0.5A
Auxiliary output : ±12V 0.5A
Accuracy of voltage stabilization±3% @ 220VAC
Continuous power350W
Rated power700W
Peak power900W
EfficiencyMax. 98%
Dimensions96 x 96 x 38mm
Weight310g
InputScrew terminals
OutputScrew terminals
OutputPCB Connector
Output voltage (V)12.0
Output voltage (V)40.0
Output current (A)0.5
Output current (A)6.5
Input voltage (V)220.0
Input voltage (V)230.0
Input voltage (V)240.0
Power SupplySMPS
Très pratique mais Bruyant
Alimentation qui est bien pensé, pratique avec des sorties 12V ventilateur, +-12V auxiliaire en plus de la tension principale, le tout sur borniers, très appréciable. Il fait le job d'alimenter mais le seul bémol il est bruyant. Je suppose au prix vendu , il ne faut pas s'attendre à mieux.
This review has been posted for Switching Power Supply Module 700W +/-40V
This LLC switch mode power supply module has a main output delivering ±40V. The resonant circuitry uses a high frequency sine wave,...
