Extremely well made especially for the price. No internal wires, ALPS switcher, high quality aluminum enclosure. Perfect.
As always, Audiophonics offer exceptional service and fast shipping.
This Audiophonics RCA source selector lets you connect different analog sources to an amplifier, preamplifier or active loudspeakers. Its function is to enable permanent connection of multiple sources (up to 4) to a single amplification device. Once the source selector has been integrated into a complex audio installation, simply use the rotary knob to select the active source.
As a passive device, it can also be used in reverse, sending one source to several amplifiers, for example. The advantage of a source selector is that you can enjoy the convenience of changing sources without touching the connections of your Hi-Fi system. It also preserves the life of the system's mechanical parts (connectors, plugs, cables), as they are less subject to frequent handling.
Selection should be made with the amplifier switched off, to avoid switching noise. Input and output grounds are common.
Source selection is made by a single accessible knob on the front panel. This rotary knob acts on a ALPS PCB-mounted mechanical selector to switch the signal. Digital markings corresponding to the RCA inputs facilitate source identification.
This type of completely passive assembly is appreciated for its very low sound coloration.
The 4 stereo RCA analog inputs allow you to connect as many sources as you like. The gold-plated connectors ensure good conductivity and a clear signal. Internal connections are made directly to PCB.
The whole unit is housed in a 100% aluminum case, protecting it from shocks, interference and noise.
Product type | Input selector |
Power supply | Passive |
Inputs | 4* RCA stereo |
Outputs | 1* RCA stereo |
Selection mode | Rotary knob |
Chassis | Aluminum |
Dimensions | 185*230*45mm |
Weight | 1.2kg |
Package | 1* Audiophonics RCA 4 to 1 reversible source selector |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Panikos K.
Louis M.
