DOUK AUDIO MC303 Passive Audio XLR Selector Switch
New
The Douk Audio MC303 is a passive XLR selector with 3 inputs and 3 outputs. The contacts of the XLR connectors are gold-plated for perfect signal transmission and increased resistance to corrosion and oxidation.
Reference : 20727
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 24-06-2025.
Douk Audio MC303 Passive Audio 3 to 3 XLR Selector Switch
Douk Audio MC303 picture
The Douk Audio MC303 is a passive XLR selector with 3 inputs and 3 outputs. The contacts of the XLR connectors are gold-plated for perfect signal transmission and increased resistance to corrosion and oxidation. Switches, meanwhile, feature silver-plated contacts. The MC303 allows you to select 3 different sources and 3 different outputs, for maximum listening flexibility. For example, you can connect a DAC, CD player and DVD player, and then output the signal to a preamplifier, amplifier or passive speakers.
The Douk Audio MC303 is compatible with most audio devices. However, if common ground noise exists, please add an isolation module between the MC303 and your device.
Douk Audio MC303 overview
1Input selector
2Output selector
33x XLR output
43x XLR input
Product typePassive XLR selector switch
Inputs3x XLR stereo female input
Outputs3x XLR stereo male output
Housing materialAluminum
Dimensions280 x 124 x 80mm
Weight1kg
Package1x Douk Audio MC303
InputXLR
DOUK AUDIO MC303 Passive Audio 3 to 3 XLR Selector Switch
The Douk Audio MC303 is a passive XLR selector with 3 inputs and 3 outputs. The contacts of the XLR connectors are gold-plated for perfect signal...
