Beau produit mais il faut trop de watts pour que ça bouge dommage ça restera en déco merci au service technique car ça fonctionne sur un ampli classe G réponse très rapide et ça c'est super merci .
With its LC30, Fosi Audio unveils an amplifier and speaker selector. In other words, it allows you to switch easily and quickly between two power amplifiers and two pairs of passive speakers. This device is ideal if you want to take advantage of two Hi-Fi systems, or if you want to carry out comparative tests. Fosi Audio has chosen to integrate two relatively impressing VU meters on the front of its LC30 to give it a vintage look. The LC30 also features a remote control for added convenience and a comfortable user experience.
In terms of technical specifications, the LC30 supports up to 2x 250W under 4ohm power and is compatible with most power amplifiers on the market: class A amplifiers, class A/B amplifiers, class B amplifiers, class D amplifiers, mono amplifiers (BTL) and tube amplifiers. A large potentiometer adjusts the intensity of the VU meters according to the input signal power, and a 4-level light intensity setting (100%, 75%, 50%, Off) is also available. All LC30 components are housed in a durable aluminum case.
"The LC30 from Fosi brings us a high quality fun meters with switching ability. If you just want dancing meters, I suggest tapping from the amplifier speaker binging to LC30 and not routing your signal through it. If you are going to use it as an AB switch, you should invest in proper set of short cables. The build quality is excellent and the unit is one of the most beautiful of its kind. I am going to recommend the Fosi LC30 meter and speaker/amplifier switcher for fun factor."
Product type | Audio selector for amplifiers / speakers |
Inputs | 2x Amplifier input on speaker terminals |
Outputs | 2x Speaker output on speaker terminals |
Maximum supported power | 2x 250W @ 4 ohms |
Vumeters brightness adjustment | 4 levels : 100%, 75%, 50%, Off |
Anti-pop protection | Load protection up to 390Ω |
Power supply | 5V DC via USB-C |
Dimensions | 236.6 x 143.5 x 77.4mm |
Weight | 1560g |
Color | Black / Yellow Vu-meter |
Package | 1x Fosi Audio LC30 1x USB-C/A to USB-C cable 1x Remote control |
Average votes 4.0 / 5 4 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Jean-Pascal H.
Olivier C.
Douwe v.
David L.
