ATOHM FURTIVE 1-1 HiFi Wall Speaker 120W / 6 Ohm Black (Unit)
By buying this product you get 39 loyalty points
Reference : 11244
399,00 €tax incl.
332,50 € tax excl.
Last items in stock !
Shipping date: 25-09-2026.
The FURTIVE wall cabinet is the result of the desire to combine elegance and exceptional acoustic performances. A resolutely contemporary design, a reduced depth are all arguments facilitating a harmonious integration in your interior.
Youyou will find in the attached documents 2 PDF files on the FURTIVE range of ATOHM.
Features:/ Strong>
  • Enclosure: 2 closed channels
  • Power Rating: 70Weff
  • Peak power: 120W
  • Impedance: 6 Ohm
  • Sensitivity level: 88dB / 2.83V / 1m
  • Frequency Response: 80Hz - 25kHz
  • Switching Frequency: 3kHz
  • Boomer low medium: LD130CR04
  • Tweeter: SD20ND04F
  • Slope of filtering: 1st electrical order with timing of the tweeter
  • Case: MDF 19mm
Packaging:
  • Finish: Satin black
  • Dimensions: 220x350x100mm
  • Weight: 4.5kg
  • Wall bracketprovided
  • Sold individually
Impedance (Ω)6
Loudspeaker diameter (mm)N/A
Efficiency / Sensitivity (dB)88.0
Lowest frequency (Hz)80
Highest frequency (Hz)25000
Power (W)120.0
Number of ways2
Number of loudspeakers2
Speaker typePassive
Speaker form factorWall / in-wall speaker
