Pack SMSL AD18 V3 FDA / Q ACOUSTICS 3010i Speakers / Speaker Cables OFC 24K 3m
Pack FX-AUDIO D802C FDA / Q ACOUSTICS 3010 / OFC speakers Wires 2m
This pack consisting of an amplifier Full Digital SMSL AD18 and a pair of loudspeakers Q Acouctics 3010i fintion Graphite Black will be perfect for a HIFI channel in mini format with a great sound.
By buying this product you get 43 loyalty points
Reference : 12348
439,00 €tax incl.
365,83 € tax excl.
Shipping from France
Billing in France
Technical support in France
Pack content
This pack consisting of an amplifier Full Digital SMSL AD18 V3 and a pair of loudspeakers Q Acouctics 3010i fintion Graphite Blackwill be perfect for a mini HIFI channel with a big sound.
This pack is also composed of of a pair of enclosure cables OFC copperwith banana plugs, a length of 3 meters with red sheath of the most beautiful effect.
Thus you have a high fidelity channel in a compact format with the sound of English productions bringing warmth, dynamics, melodic meaning typical of this type of realization.
The 3010i has many new aspects, both internal and external. The new tweeter and drive motor allow the new 3010i enclosure to deliver exceptional performance especially at the bottom of the spectrum. This pair of speakers redefines sound performance standards in its class.
The FDA amplifier SMSL AD18, rewarded Qobuzissime by Qobuz, has all the necessary embedded technology. With its interface SPDIF CS8422, its capabilities Wireless Bluetooth 4.2 NFC and its output Subwoofer, it will be able to transcribe the least musical information of your computer or other digital apparatus with more than 2x60W under 8 Ohm.
An excellent compromise between High Definition and compactness that will bring great musical satisfaction to music loverswanting to sacrifice place and inner aesthetics at content prices.
Pack content:
  • 1 pair of Speakers Q Acoustics 3010i Graphite Black
  • 1 Amplifier SMSL AD18 V3 TAS5342A Bluetooth NFC
  • 1x Pair of cables HP OFC bananas 3m with protective sleeve red
Features SMSL AD18 V3:
  • SPDIF Interface: CS8422
  • Interface USB: VT1620A (16bit 44.1kHZ-192kHZ, 24 bit 44.1kHZ-96kHZ)
  • Color display TFT 1.44
  • Bluetooth Interface 4.2 NFC: CSR A64215 A11u
  • FDA Controller: TAS5508C
  • Amplifier Module TAS5342A: 2 x 80W under 4 Ohm, 2x 65W at 8 Ohm
  • Headphone amplifier chip: MAX97220A
  • Double Op-Amp NE5532
  • Total harmonic distortion: 0.04%
  • Frequency Response: 18Hz - 22kHz
  • Digital equalizer with 7 positions (correction +/- 8dB)
  • Color display
  • Digital Inputs: S / PDIF Optical Toslink, Mini Optical Coaxial and Micro USB-B
  • Analog inputs: One input on 3.5mm stereo jack
  • Input on DC jack: Power supply 24V 5A
  • Wireless Input Bluetooth BT4.2 Signal Noise Ratio 90DB
  • Outputs HP: On screwed terminal blocks supporting banana plugs 2.5mm
  • Subwoofer output (SW): on 3.5mm jack port "COAX / OPTI1"
  • Headphone outputs: on 32Ohm 53mW @ THD = 0.04%
Q Acoustics 3010i :
  • Enclosure Type: 2-way SLR
  • Woofer: 100mm
  • Heavy-duty motor: 22mm
  • Frequency Response: 65Hz - 30kHz
  • Nominal impedance: 6 ohm
  • Minimum impedance: 4 ohm
  • Sensitivity: 86 dB
  • Recommended power: 15 - 75w
  • Transition Frequency: 2.6 kHz
  • Dimensions H / W / W mm: 150x253x252mm
  • Weight: 4.1kg per speaker
  • 5 Year Warranty
[Img-25956-left-large_default_2x]
ColorGray
Speaker Power (W RMS)75.0
Number of ways2
Number of loudspeakers2
Superbe
Je voulais attendre quelques jours pour donner mon avis histoire de roder un peu les enceintes. Tout d'abord je tiens à remercier l'équipe de Audiophonics chez qui je n'ai aucune action qui ont toujours répondus à mes nombreux mails d'interrogations.
Donc cet ensemble très compact fonctionne à merveille croyez-moi C'est trs doux à faible volume et pendent des heures d'écoute on ne se lasse jamais et si vous montez le son ça suit et ça ne bouge pas.J'avais peur d'un manque de basse au début mais non c'est très naturel comme son et depuis le rodage effectué pas moins de 50 heures c'est mieux. Alors foncez un rapport qualité/prix imbattable!!!
This review has been posted for Pack SMSL AD18 V3 FDA / Q ACOUSTICS 3010i Speakers / Speaker Cables OFC 24K 3m
This pack consisting of an amplifier Full Digital SMSL AD18 and a pair of loudspeakers Q Acouctics 3010i fintion Graphite Black will be perfect...
