Q Acoustics 3060S Active Subwoofer 150W Graphite Grey
By buying this product you get 37 loyalty points
Reference : 13487
379,00 €tax incl.
315,83 € tax excl.
Subwoofer 3060S Q Acoustics
serious caison active 150W Class D 35-250Hz - Adjustable crossover
QAcoustics 3060S 150W Subwoofer
The subwoofer 3060S of at Q Acoustics embeds a speaker 200mm and an integrated 150W amplifier.
If he follows the aesthetic line of Q3000i series of the same manufacturer, Q3060s will work with any home cinema system to bring real depth in the bass.
qacoustics bass speaker
The controls and connections are hidden under a magnetic hatch. The input connector is angled such a way that the plugged cable do not exceed ungracefully from the device.
The crossover and the volume are adjustable from the outer panel. The crossover can be set anytime between 35 to 250Hz.
The enclosure is built as infinite baffle. This type of housing is ideal for high-performance low-frequency speakers.
The box can be installed on a piece of furniture thanks to the four spikes provided. It can be installed directly on the floor with additionnal (non included) rubber feet as well.
subwoofer with crossover
Enclosure Typeinfinite baffle
Frequency response (+3 dB, -6 dB)35-250 Hz
Amplification power150W
frequency crossover35-250Hz (variable)
ClassD
Dimensions480 x 300 x 150 mm
Weight8.5kg
Package Contents
Active subwoofer 3060sx1
Spikesx4
Power cablex1
User Manualx1
ColorGray
Impedance (Ω)NC
Loudspeaker diameter (mm)N/A
Lowest frequency (Hz)35
Highest frequency (Hz)250
Power (W)150.0
Number of loudspeakers1
Speaker typeActive
