Material
Diameter (mm)
Height
mm
mm
Arvydas V.
A
Mohammed B.
Im Vergleich zu Mundorf...
Mohammed B.
Spikes
Spikes are useful to limit the transmission of any vibrations liable to cause interference from one surface to another. Very effective on speaker cases. Also works all kinds of HiFi devices with massive housing. Available in several options: different threadings, materials, type of decoupling and colors.
  • Ref : 15333
    In Stock
    This decoupling tip is made of Aluminium. It is surrounded by a removable rubber ring. The combination of these two materials allows the absorption of different frequencies. The assembly is done thanks to the M4 thread integrated in the tip.
    1,90 € 1,58 €Ex.
    In Stock
  • Ref : 15537
    In Stock
    2,90 € 2,42 €Ex.
    In Stock
  • Ref : 2945
    In Stock
    These Dynavox decoupling spikes provide your HiFi audio equipment with better stability while allowing it to diffuse vibrations to its support so that it is not affected by them.
    6,50 € 5,42 €Ex.
    In Stock
  • Ref : 14424
    In Stock
    The Viablue HS Spikes help to limit vibrations from your speakers or devices to underlying surfaces. This results in a clear, precise and detailed sound reproduction. The spikes are an ideal addition to your speakers and devices such as CD players or amplifiers and tubes.
    98,00 € 81,67 €Ex.
    In Stock
  • Ref : 15231
    In Stock
    98,00 € 81,67 €Ex.
    In Stock
  • Ref : 15026
    In Stock
    These Viablue QTC Spikes Disc metal decoupling pins prevent vibration transmission from your speakers or devices to the lower surfaces. Their acoustic properties also contribute to obtaining a precise, detailed and clear sound reproduction.
    258,00 € 215,00 €Ex.
    In Stock
  • Ref : 15027
    Reduced price!
    In Stock
    206,40 € 172,00 €Ex.
    258,00 € In Stock
  • Ref : 14002
    In Stock
    Viablue TRI Spikes tips effectively discharge harmful vibrations via three spikes. This system prevents the propagation of vibrations on the surface on which your device is placed. The unique design of these spikes helps to provide a precise, clean and detailed sound.
    248,00 € 206,67 €Ex.
    In Stock
  • Ref : 17814
    In Stock
    Xangsane's XS-A012 aluminum feet feature an adjustable pure copper decoupling spike. They provide highly effective vibration and shock absorption for a richer, more natural sound. They can be used with all types of equipment, including amplifiers, speakers and subwoofers. Four XS-012 feet can support up to 50kg.
    19,90 € 16,58 €Ex.
    In Stock
  • Ref : 17815
    In Stock
    19,90 € 16,58 €Ex.
    In Stock
