ARYLIC UP2STREAM HD DAC Streamer ES9038Q2M WiFi DLNA AirPlay 2 Bluetooth 24bit 192kHz
The Arylic Up2Stream HD DAC presents itself as a network player with integrated DAC, both versatile, practical and scalable, which will allow you to set up a complete and powerful streamer, including in multi-room.
Reference : 15952
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 27-06-2025.
Arylic Up2Stream HD DAC Lecteur réseau ES9038Q2M WiFi DLNA AirPlay 2 Bluetooth 24bit 192kHz
The Arylic Up2Stream HD DAC presents itself as a network player with integrated DAC, both versatile, practical and scalable, which will allow you to set up a complete and powerful streamer, including in multi-room. Thus, its digital to analog conversion stage uses an ESS ES9038Q2M chip, allowing it to provide accurate sound reproduction, while supporting audio streams up to PCM 24bit 192kHz. Furthermore, the Up2Stream HD DAC can be extended with a number of optional modules (sold separately), such as a display, control buttons or even an acrylic case.
AirPlay 2 compatible
The Up2Stream HD DAC is compatible with the recent Apple AirPlay 2 transmission protocol. This makes it possible to stream music easily and quickly from an iOS smartphone.
Spotify Connect & Tidal Connect
The Up2Stream HD DAC is also compatible with Spotify Connect and Tidal Connect protocols. These allow you to stream your music directly from these services, without having to use an application such as 4Stream.
Multiroom
Several Up2Stream HD DAC modules can be used together to create a true multiroom environment, allowing you to stream and control your music in any room of your home. They can also be combined with other Arylic modules to create a complete DIY multiroom system.
Many streaming services available
The Up2Stream HD DAC is compatible with many music streaming services: Qobuz HD, Tidal HiFi, Spotify, Deezer, Amazon Music, Napster, but also many web radios are thus at your disposal.
4Stream
It's extremely easy to control the Up2Stream HD DAC remotely, thanks to the free 4Stream mobile app. Available for Android and iOS, it will allow you to manage your music playback, access your playlists or even set an alarm.
Application 4Stream Android Application 4Stream iOS
Product typeStreamer
ConnectivityWiFi IEEE 802.11 b/g/n 2.4G / 5G
Bluetooth 5.0 (support aptX HD)
Inputs1x Ethernet RJ45 10/100Mbps
1x Digital input on PCB connector
1x AUX input on PCB connector
Outputs1x Stereo RCA
1x Coaxial
1x Optical
1x I2S Output on PCB connector
1x AUX Output on PCB connector
Supported streaming protocolsAirPlay 2
DLNA
UPnP
Spotify Connect
Tidal Connect
Qplay
DAC ChipESS ES9038Q2M
Supported sampling ratesPCM up to 24bit 192kHz
Supported file formatsFLAC, MP3, AAC, AAC+, ALAC, WAV
Compatible streaming servicesTidal HiFi
Qobuz HD
Spotify
Deezer
Amazon Music
TuneIn
Napster
iHeartRadio
QQFM
Supply voltage5VDC 2A
Dimensions110 x 74mm
Weight81g
InputPCB Connector
InputRJ45
OutputI2S
OutputOptical Toslink
OutputCoaxial SPDIF
OutputPCB Connector
DAC / ADC ChipES9038Q2M
Max sampling rate192kHz
Streaming services & Network protocolsTidal Connect
Streaming services & Network protocolsDeezer
Streaming services & Network protocolsWeb radios
Streaming services & Network protocolsSpotify Connect
Streaming services & Network protocolsQobuz
Streaming services & Network protocolsAmazon Music
The Arylic Up2Stream HD DAC presents itself as a network player with integrated DAC, both versatile, practical and scalable, which will allow you...
