DAYTON AUDIO SPA1000 Subwoofer Amplifier Module 1000W 4 Ohm
The Dayton Audio SPA1000 is one of the most technologically advanced subwoofer amplifiers on the market. It is based on a Class G circuit combining the high power and fidelity of a Class AB amplifier with a patented power supply to achieve an incredible 86% efficiency.
By buying this product you get 62 loyalty points
Reference : 14766
629,00 €tax incl.
524,17 € tax excl.
Last items in stock !
Shipping date: 30-04-2025.
Dayton Audio SPA1000 Module Amplificateur Subwoofer 1000W
The Dayton Audio SPA1000 is one of the most technologically advanced subwoofer amplifiers on the market. It is based on a Class G circuit combining the high power and fidelity of a Class AB amplifier with a patented power supply to achieve an incredible 86% efficiency. The SPA1000 offers the efficiency of a Class D system without compromising on audio quality. The Class AB output stage provides very low distortion for pure sound, without the jitter problems found in many high-output amplifiers.
The SPA1000 is an American-designed, patented circuit that constantly monitors the input signal to modulate or control the voltage available at the output stage. This tracking capability allows the SPA1000 to deliver exactly the power required, without creating a reserve, so that the output stage has the necessary power available at all times. As a result, less energy is dissipated as heat and more power is available to power your subwoofer. With its advanced thermal management, the SPA1000 offers a real improvement over previous models, making it a foolproof amplifier choice for demanding audio applications.
Before installing, connecting and operating the SPA1000, make sure that the selected power supply voltage matches the voltage delivered by your power outlet. Refer to the manual available for download to perform this operation.
Product typeSubwoofer amplifier module
Entrées1x Stereo RCA
1x Direct LFE
Rated power497 @ 8Ω
950W @ 4Ω (0.92% THD)
SNR98dB (A-Weighted)
Low pass crossover30Hz - 200Hz, 24dB/octave
Parametric EQFrequency : 18Hz - 80Hz
Bandwidth : 0.1 - 1 Q
Level : -14.5dB à +6dB
Phase adjustment0° (NOR) or 180° (REV)
Input impedance12kΩ
Efficiency86%
Switchable voltage supply115V
230V
Consumption115V : 24W
230V : 18.4W
Dimensions30.3 x 30.3 x 13.3cm
Cutout dimensions25.4 x 25.4cm
Weight7.7kg
OutputNC
Amplifier chipN/A
Power (W)1000.0
The Dayton Audio SPA1000 is one of the most technologically advanced subwoofer amplifiers on the market. It is based on a Class G circuit combining...
