JJ ELECTRONIC ECC82 / 12AU7 GOLD Twin triode tube (Matched Pair)
The ECC82 / 12AU7 GOLD tube from JJ ELectronics is a double triode offering good performance, smooth tones and clear definition. It is designed to provide two balanced triodes for stereo or balanced amplifier stages. Furthermore, the gold pin coating provides unbeatable protection against oxidation. This tube can also replace the 12AU7/ECC82/6189/CV4003 tubes.
4.5 / 5
Reference : 19320
94,00 €tax incl.
78,33 € tax excl.
Shipping date: 25-06-2026.
3 >Month warranty
JJ ELECTRONIC ECC82 / 12AU7 GOLD : Front view
JJ ELECTRONIC ECC82 / 12AU7 GOLD : Data and dimensions
Product typeTube
Tube typeTwin triode
Number of pins9
DimensionsØ22.2 x 53.3mm
Weight13g
ELECTRICAL PARAMETERS
Filament heating voltage (Uf)6.3V - 12.6V
Filament heating current (If)300/150mA
Anode operating voltages (Ua)250V
Grid control voltage (Ug)-8.5V
Anode current (Ia)10.5mA
Mutual inductance (S)2.2mA/V
Control grid impedance (Ri)7.7kΩ
Amplification power (μ)17
MAX VALUES
Anode voltages (Ua)300V
Anode dissipation (Wa)2.75W
Cathode current (Ik)20mA
Grid control voltage (Ug)-50V
External resistor control grid1MΩ
Cathode voltage (Uk)180V
Cathode resistor (Rk)150kΩ
PackageSold by pair
Contacts number9
Tube typeDual Triode
2 reviews
These are great. Recommended!
Purchased these to swap stock tubes on my Xduoo TA-22 paired with Hifiman Arya Stealth. There is a very notable difference right out the box. The sound is much more detailed and dynamic.
This review has been posted for JJ ELECTRONIC ECC82 / 12AU7 GOLD Twin triode tube (Matched Pair)
Super détaillées
Montées en lieu et place sur un préampli maison ( Base schéma Quad année 70 cascode) pour remplacer des anciens tubes de chez National USA de 40 ans d'âge plus pas curiosité que par nécessité car les Nationals donnaient de super résultats.
Dès les premières écoutes il me semble que j'ai perdu en peu en gain mais c'est pas grave car j'ai gagné sur la définitions et la précision ainsi que sur les attaques les graves sont profonds mais ne bavent pas (contrairement au Nationals qui trainaient u peu) l'aigue monte haut sans crier j'aime beaucoup , passé 3 jours pas de gain notable on verra dans 2 semaines mais j'ai toujours des doutes quand à la nécessité de rodage je pense que c'est plutôt l'auditeur qui s'habitue au nouveau son.
Deux points qui m'empêche de mettre 5 étoiles :
- Son moins tube, plus froid, le prix de la clarté sans doute et des enceintes haut rendement qui ne pardonnent rien mais la sensation d'espace le positionnement des instruments l'extinction des notes sublimes propres aux tubes sont bien là.
- Le prix un peu élevé bien que la qualité ressenti notamment au niveau des contacts or puisse le justifier.
Si dans 2 semaines le rodage fonctionne je posterai un nouvel avis.
Conclusion je conseille
The ECC82 / 12AU7 GOLD tube from JJ ELectronics is a double triode offering good performance, smooth tones and clear definition. It is designed to...
