PSVANE EL34-PH HiFi Tubes (Matched Quad)
PSVane's EL34-PH tube is a replica of the well known Philips EL34, widely used in many tube amplifiers. The EL34-PH is characterized by a soft and musical sound signature. It is also capable of withstanding high voltages, up to 800V, to provide high power output.
By buying this product you get 32 loyalty points
Reference : 14716
329,00 €tax incl.
274,17 € tax excl.
Shipping date: 17-06-2025.
3 >Month warranty
PSVANE EL34-PH quad
HiFi Tubes (Matched set x4)
PSVANE EL34-PH Tubes HiFi (Set x4 Appairés)
These tubes are delivered in sets of 4 and are matched by the brand to obtain the closest values and therefore the best possible operation. Ideal for a perfect assembly.
1NC
2Filament
3Anode
4Screen grid
5Control grid
6NC
7Filament
8Cathode
Suppressor grid
Product typeTubes
Tubes modelEL34-PH
Filament heating voltage6.3V
Filament heating current1.5A
Nominal limits
Anode voltage800V
Grid 2 voltage500V
Grid 1 voltage-100V
Anode dissipation power25W
Grid dissipation power8W
Cathode current150mA
Grid 1 Resistance
Automatic bias0.7MΩ
Fixed bias0.5MΩ
Cathode voltage between filaments±100V
Interelectrode
Input capacitance15.2pF
Output capacitance8.4pF
Transfert capacitance1.1pF
Capacitance between grid 1 filaments1pF
Capacitance between cathode filaments10pF
Static parameters
Ua250V
Ug2265V
Ug30V
-Ug113.5V
Ia100mA
Gm11mA/V
Ri15kΩ
Mg1-g211
DimensionsØ32 x 120mm
Quantity4 matched tubes
Contacts number8
Tube typeN/A
7 reviews
Smooth sounding EL-34s
J'écris cet avis en Anglais pour qu'il soit lisible de tous.
I share the other comments when it comes to Tube break-in. I went from Electro-Harmonix tubes (OEM on my Synthesis Roma) to these PSVANEs. At first the sound was dark and fuzzy. The voices were not forward anymore but in the far back of the sound stage. It's a derouting experience when you know they cost quite a fortune. But after 20 hours of listening the sound began to open.
Quickly after, voices were soft, warm, soundstage was clearer, and the highs were clearer.
Once you let these babies break in sufficiently, you get a good upgrade and lushy sound.
Tubes on themselves are gorgeous and the packing is top-notch. You have a verification sheet that proves the matching of the tubes with obtained results from the factory (handwritten).
The minor con I see is in the price/benefit ratio. You need to embrace diminishing returns with these tubes. Compared to my mid-life OEM Electro-Harmonix, these PSVANE brought just around 20% of an upgrade (if you consider slightly more open sound stage and clearer highs). But if it had to be done again, maybe I would've spent these 350€ somewhere else for more results.
Note : I'm using these tubes after an excellent phono preamp, on a mid-tier Tube Amp (Roma96DC), listening on vinyl only over wonderful vintage Cabasse speakers.
This review has been posted for PSVANE EL34-PH HiFi Tubes (Matched Quad)
Grandiose !
Après le re- tubage de la partie pré amplification de mon Cayin cs55a avec des tubes PSVANE qui avait bouleversé les caractéristiques sonores de cet ampli, voici le tour des tubes de puissance.
Je ne savais pas vraiment à quoi m’attendre, tout au plus à une petite augmentation de puissance.
Je confirme donc les avis laissés plus haut de Laurent H et Robert V.
Chez moi, j’obtiens un système énorme avec un son d’une ampleur inédite.
Mes petites DALI Menuet chantent comme des grandes Utopia. Je ne sais pas comment décrire autrement la sensation d’un son, à l’échelle 1/1. Les instruments sont pour le coup véritablement incarnés. Les timbres sont parfaitement retranscrit avec toutes les nuances possible avec une taille réaliste.
Ça manque un peu de profondeur et de largeur ; un peu…
Évidemment ça donne envie de tester les PSVANE KT88-T2 vendues dans cette même boutique.
Je pense que pour avoir le meilleur des deux monde, il faut passer sur des amplificateurs plus onéreux avec des tubes exotiques de type 845 - 805 ou autre 300B.
 (3)
Excellent tube el34
Je possède un ampli cayin cs-88a avec des lampes kt88. J'ai voulu tester une bonne lampe el34. Effectivement cette lampe est vraiment excellente. Par rapport au kt88 genalex gold. Plus de texture, une écoute plus émotionnel, des basses tendus et plus de nuances pour les voix. Par contre le kt88 est plus dynamique, une image beaucoup plus grande en largeur et en hauteur. Plus de basses et le son est plus tendu. A part le prix je ne regrette pas mon achat. Pour info le rodage n'est pas encore terminé.
 (4)
PSVANE tubes
The first switch-on, a fuzzy, obscure, crooked, bad sound, but improving during burning, after 30 hours of listening accurate fast bass, beautiful clean mids and highs with perfect microdynamics, amazing holography 3D stage, very nice warm character, I think they are the best from EL34 line, (better than everything I've heard so far including gold lion kt88) the only small disadvantage for me (just when compare) is not such dynamics and such deep bass as on KT88. I am very very happy with this.
 (4)
the best matched EL34 quad you can possibly find
Suggested by a friend and quite many positive reviews I ordered and promptly received the Psvane EL34-PH matched quad from Audiophonics
I put them on my Audio Innovations 800mkIII valve poweramp: immediately greater and clearer sound! Bigger scene more detailed and musical. I am really happy and super impressed!
I believe I will keep these tubes on for a long while and will try Psvane again whenever I will need to change other tubes
 (3)
PSVane's EL34-PH tube is a replica of the well known Philips EL34, widely used in many tube amplifiers. The EL34-PH is characterized by a soft...
