TUNG-SOL EL34B Tubes Pentodes Platinum (Matched Quad)
These Tung-Sol EL34B high voltage pentode tubes feature a beautiful design, using high quality materials. They have a high impedance with an increased reactivity. They can also be used to replace 6CA7 tubes. In addition, these four tubes are matched to provide the best performance.
Reference : 15699
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 16-12-2025.
3 >Month warranty
Tung-Sol EL34B
Tubes Pentodes Platinum Matched (Matched Quad)
Tung-Sol EL34B Tubes Pentodes Platinum Matched (Quad Appairés)
# PinElectrode name
1Grid 3
2, 7Heater
3Plate
4Grid 2
5Grid 1
6NC
8Cathode
Product typeTubes
Tubes typePentode
Number of pins7
Quantity4 Matched tubes
Measurements
ParameterConditionsMin.Max.
First grid reverse currentFilament voltage 6.3V, plate voltage 250V, first grid voltage minus 13.5V, second grid voltage 265V, first grid circuit resistance 0.51MΩ-1.5µA
Heater current-1.35A1.65A
Plate currentFilament voltage 6.3V, plate voltage 250V, first grid voltage minus 13.5V, second grid voltage 265V80mA130mA
Second grid currentFilament voltage 6.3V, plate voltage 250V, first grid voltage minus 13.5V, second grid voltage 265V10mA20mA
Output powerFilament voltage 6.3V, plate voltage 250V, first grid voltage minus 13.5V, second grid voltage 265V, plate circuit resistance 2kΩ8.5W-
First grid cut-off voltage, negativeFilament voltage 6.3V, plate voltage 250V, second grid voltage 265V-38V
Distortion factorFilament voltage 6.3V, plate voltage 265V, first grid voltage minus 13.5V, second grid voltage 265V, plate circuit resistance 2kΩ-13.5%
Cathode - Heater insulation resistanceFilament voltage 6.3V, cathode heater ±100V2MΩ-
Limit values
ParameterMin.Max.
Filament voltage5.5V7V
Cathode - Heater voltage-±100V
Cathode current-150mA
Plate dissipation power-25W
Second grid dissipation factor-8W
first grid circuit resistance, fixed bias-0.5MΩ
first grid circuit resistance, self bias-0.7MΩ
Temperature at the most heated part of the envelope-523K°
Contacts number7
Tube typePentode
11 reviews
Perfect
Lamps sounds kood with smooth soft juicy bass and neitral hights. recomend for classic music
This review has been posted for TUNG-SOL EL34B Tubes Pentodes Platinum (Matched Quad)
EL34
The tubes arrived well packaged, after the first connection, the sound was quite decent, significantly improved after the burn-in, excellent tubes for a few euros, thank you for the fast delivery
Great sound for the price
These tubes are not as prone to failure as the Chinese ones, they are made solidly and will serve for many years. They give a very saturated, soft sound, with beautiful mid tones, good bass and a sonorous top of the band. Worth recommending, they have a great value for money.
Tung
Un son plus détaillé et limpide. Content.
Génial
Je les utilise au lieu des J&J EL34s sur mon ampli intégré. Je suis totalement satisfaite de cet achat. Un grand merci à Audiophonics.
These Tung-Sol EL34B high voltage pentode tubes feature a beautiful design, using high quality materials. They have a high impedance with an...
