Connector
Max sampling rate
DAC / ADC Chip
Class
Connectic
Contacts Material (Connector)
Contacts Plating (Connector)
Input
Output
Remote Control
Networking
Color
Sylvain H.
USB Adapters
USB adapters are essential for many devices with this connection. The USB standard is available in many variants, such as USB-B, USB-A, or more recently USB-C (also known as USB Type C). Micro-USB to USB-A adapters are widely used for smartphones or computers.
  • Ref : 20626
    In Stock
    This USB4 adapter consists of a male USB-C connector and a female USB-C connector. It supports high bandwidth of up to 40Gbps and 8K 60Hz video streams. Furthermore, this connector is capable of supporting up to 140W of power, perfect for fast charging. Moreover, its aluminium alloy body makes it a robust and elegant model, and the detachable, magnetic...
    6,90 € 5,75 €Ex.
    In Stock
  • Ref : 14881
    In Stock
    This xDuoo X-C06 adapter has a standard USB-A female connector and a Sony WM Port proprietary connector. It allows you to connect a peripheral such as a computer for example to a Sony device equipped with this connector.
    11,90 € 9,92 €Ex.
    In Stock
