ATAUDIO AT-M015 USB-C Male to USB-B Male Cable 0.5m
The ATAUDIO AT-M015 is a USB cable designed to connect devices with USB-C and USB-B ports in a digital audio setup.
Reference : 22435
17,91 €tax incl.
14,92 € tax excl.
ATAUDIO AT-M015 Male USB-C to Male USB-B Cable Shielded 6N OFC Copper 0.5m
ATAUDIO AT-M015
The ATAUDIO AT-M015 is a USB cable designed to connect devices with USB-C and USB-B ports in a digital audio setup. It uses four 6N OFC copper conductors, each consisting of 40 copper wires, to ensure good conductivity. Its design incorporates a PVC sheath, a cotton cord filler with strain relief reinforcement, an insulating paper layer, as well as tinned copper braided shielding to protect the connection against external interference. The AT-M015 thus combines a multilayer design and dedicated shielding for stable USB transmission, while benefiting from a construction designed to provide good mechanical resistance.
ATAUDIO AT-M015
Technical Specifications
Product TypeUSB interconnect cable
Connectors1x USB-C
1x USB-B
Cable Material6N OFC Copper
Conductor Structure4x 40 OFC Copper Strands
InsulationPVC
ShieldingTinned Braided Shielding
Interference Protection Rings
Connector HousingAluminum
Connector PlatingGold
Outer SheathBraided Nylon
Cable DiameterØ7mm
Length0.5m
Package Contents1x ATAUDIO AT-M015
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorUSB-C
ConnectorUSB-B
ATAUDIO AT-M015 USB-C Male to USB-B Male Cable Shielded 6N OFC Copper 0.5m
