The DDHiFi HS650-Hub is a versatile USB hub designed to easily expand the connectivity of a computer or audio setup. It features two USB-C ports and one USB-A port on the front, compatible with USB 3.0 and offering speeds of up to 5 Gbps, as well as one USB-C input port and one USB-A port on the rear. It also supports Power Delivery (PD) fast charging up to 100W, allowing it to meet the needs of compatible devices. Originally designed to be integrated into the DDHiFi HS650 desktop stand using the two M3 mounting holes on its base, the HS650-Hub can also be used independently without the stand, offering greater flexibility in installation. Its CNC-machined aluminum housing and various mounting options contribute to a neat integration both on a desktop and in an audio setup.
Technical Specifications
| Specifications | |
| Product type | USB Hub |
| Inputs | 1x USB-C 3.0 1x USB-C PD 100W |
| Outputs | 2x USB-C 3.0 (5Gbps / 350MB/s) 1x USB-C 3.0 1x USB-A 2.0 |
| Body material | Aluminum alloy |
| Mounting holes | 2x M3 |
| General | |
| Dimensions | 108 x 27 x 13.3mm |
| Weight | 45g |
| Package contents | 1x DDHIFI HS650 Black USB Hub 1x USB-C 3.1 Cable |
| Length (m) | N/A |
| Shielding | NC |
| Section (mm²) | N/A |
| Connector | USB-C |
| Connector | USB-A |
| Conductors material (Cable) | N/A |
| Conductors Plating (Cable) | NC |
