With LD TC1, FIIO presents a USB-C to USB-B cable incorporating high-purity copper conductors for pure, stable signal transmission. Gold-plated connector contacts resist corrosion and oxidation. This cable ensures interference-free data transmission and limits jitter. Multiple insulations cover the conductors to guarantee a high level of shielding. The cable is then covered with a PVC sheath and a second, braided, high-quality nylon sheath. The body of the connectors is made of an aluminum alloy for robustness and durability. The LD TC1 is perfect for connecting a smartphone, tablet or computer with USB-C port to a DAC equipped with USB-B connectivity, such as the FIIO K5 Pro or FIIO K9 Pro, for example.
The cable does not support devices requiring more than 200mA current and is not suitable for recharging the battery of connected devices.
FiiO's LD TC1 USB cable has a structure worthy of top-of-the-range cables, with copper conductors and a double shield consisting of aluminium foil and tinned copper braid.
Product type | USB cable |
Connectors | 1* Male USB-C 1* Male USB-B |
Length | 0.5m |
Cable conductors material | High-purity copper Tinned copper |
Shielding | Aluminum foil Braided tinned copper |
Cable diameter | Ø5mm |
Sheath | PVC Braided nylon |
Connectors body material | Aluminum alloy |
Connectors contacts material | Copper alloy |
Connectors contacts plating | Gold |
Max. Current | 200mA |
Color | Cable: Black Connectors: Silver and black |
Length (m) | 0.5 |
Shielding | Yes |
Section (mm²) | N/A |
Connector | USB-C |
Connector | USB-B |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
